How to connect active speakers to the Nakamichi 610 pre-amp?
SOURCE: Nakamichi TA-4A receiver no sound
HAI,AMP WORKS FINE , CONNACT ANY OTHER TO AMP(CD,DVD,COMPUTER,MOBILE,TV) IN BACKSIDE INAUDIO OR PRE_AMP .THEN SELECT  PLAYER TO IN MODE YOU HAVE INSAERTED.THE SOUND IS OK
Posted on Jun 26, 2008
How do I connect a turntable to my nakamichi av-8?
This model does not seem to have a dedicated phono socket on the back. But you can connect it to the AUX socket. However in order to get any volume out of the deck. You will need to pass it through a magnetic cartridge pre-amp first. You should be able to pick one up at places such as Amazon. You plug the deck leads into the pre-amp and then the out leads into the aux socket of the av-8.
Apr 03, 2016 | Nakamichi AV-8 Receiver
How to connect a Nakamichi CMS-5 Compact Music System with Harman Kardon BDS 277
There's not a lot of info on the web about the specs and sockets on a Nak CMS-5 or the RE-5 reveiver that's part of the system. So some of this is based on the tiny fragment of information you provided.
The HK BDS277 has no outputs, only inputs. So however you decide to connect, the only way that things will work is if sound signals come from the Nak and go to the HK so that the sound comes from the HK speakers.
If the Nak has processor sockets as you have half suggested, then they act as a break point between the NAK pre-amp which does source selection and the Nak power amp that provides the muscle to drive the Nak speakers. Disconnecting the links from Processor Out/Processor In with interrupt the signal flow. You'll then be able to connect Nak Processor Out to one of the line inputs on the HK.
Any sources already connected to the Nak will then have their signals routed to the HK. The Nak speakers will be silent.
I hope this helps.
Oct 19, 2014 | Nakamichi CMS-5 CD Shelf System
I have Nakamichi CMS-5 and cassette deck DR-5. How i configure it to connect with Harman Kardon BDS 277. In CMS-5 there are 4 Jacks that read Processor, What is the purpose of those jacks. Not a singl
I hope this helps you.
How to hook up bose 901 active equalizer to onkyo grand integra pre amp?
You don't.
If you have a pre-amp/power-amp combination then the Bose equalizer connects between the two. If you're using the Bose speakers as front L&R, then the connection is between the front L & R pre-out and the power amp's front L & R pre-in.
Sep 01, 2014 | Audio Players & Recorders
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
After the recent purchase and professional installation of a used Nakamichi CD 700, I noticed my front speakers weren't working. Activating the fader adjust I noticed that when I turned the knob...
I would recommend taking it back to the pro that installed it given it hasn't been to long. Also the deck should be warrantied and if the front side is not working I would consider that a faulty head unit. I know Nakamichi head units are not cheap.
Go back to the store you purchases it from or contact Nakamichi directly at the link below:
http://www.nakamichi.com/home.html
Sep 05, 2009 | Nakamichi Audio Players & Recorders
How to connect old 901 Bose equilizer to amp/receiver
If you plan to use them with a home theater, you will need a seperate amplifier, as most a/v receivers don't have tape monitors. With an integrated amp hook rec out to the input on eq hook output on eq to playback on tape mon. with seperates hook pre amp out to input on eq, output on eq to power amp input.
Jun 23, 2009 | Bose 901 VI Main / Stereo Speaker
Speakers are connected to pre-amp or power-amp? pls explain connections , what connects with what , between cd player + pre amp + power amp + speakers.
Do this, CD audio out jacks to the PRE-AMP INPUT jacks, then PRE-AMP OUT jacks to AMPLIFIER INPUTS then from AMPLIFIER to speakers, This will work similiar with any sound source unit ie. Radio Tuner, Tape deck, etc. Just think of it this way, a PRE-AMP is BEFORE the AMPLIFIER, all the AMPLIFIER is going to do is AMPLIFY the sound to your speakers, HOPE THIS HELPS!
Feb 03, 2009 | Audio Players & Recorders
Connecting Nakamichi 600 cassette deck to speakers
You must have an amplifier or receiver to connect between deck and speakers. The deck has no power amp
Aug 03, 2008 | Audio Players & Recorders
Jun 26, 2008 | Nakamichi AV-10 Receiver
445 people viewed this question
 Grubhead
Grubhead
