Question about Frigidaire FAC124 wall/Window Air Conditioner
Air conditioner stops completely. Cannot turn it
Air conditioner stops completely. Cannot turn it back on. There is no rhyme or reason for when it decides to turn itself off. I have never set the timer. Unit is two weeks old.
  • Frigidaire Master
  • 43,501 Answers
Sounds like you have a bad motor or siring connection...return it for another one while it is still new...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
1998 grand voyager, sometimes dash works sometimes it doesn't. what can cause this ?
Could be the connector at the back of the instrument panel, or a bad connection in the wiring harness. Could also be a weak ignition switch.
Jan 25, 2014 | 1997 Plymouth Grand Voyager
Amcor aircon 15000btu
Have you tried pushing the reset button on the power plug? If the unit overheats the reset button will click on and the a/c will turn off. In order to turn it back on you will have to push the reset button.
Jul 09, 2010 | Amcor PLM-14000E Portable Air Conditioner
Need easy solution to turn off the beeping sound on Kenmore Top Freezer Fridgerator. No rhyme or reason for the beeping - driving me crazy.
there is a reason we just need to find it,open the doors one at a time and press the switch that turns the light off. do they all work? what is the complete model # starts with 3 digits then a period then 6 or so more #s.
Dec 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Carrier air conditioner cycles on and off
The compressor/condenser is being called all the time. The reason it goes off is because the evaporator (indoors) freezes up when the fan is told to turn off by the thermostat. This further cooling lowers the low side pressure below the low limit switch point turning off the compressor unit.
Solution: Make sure the thermostat is wired correctly. Green wire is usually the compressor wire but maybe not.
Jun 17, 2009 | Carrier 38BRC036 Air Conditioner
AC/heater fan on 1992 Buick LeSabre only works intermittently
Could be a bad control switch, relay or connection and ground at motor itself. Since it's intermittent, check voltages when it's working, then again when it's not. Wherever voltage stops, that's what you need to replace. Don't wait on this...when completely inoperative it gets much harder to find the problem!
Jun 09, 2009 | 1993 Buick LeSabre
Friedrich air conditioner stopped running. I was trying to find what the air conditioner was causing to vibrate near the unit. I moved the power cord while the air conditioner was running, pushed the...
This is very possible. Whenever a compressor is unplugged it should rest for about 5 minutes before turning it back on. This is because the refrigerant needs to balance. Otherwise a large amount of amperage may be required to start the compressor as it tries to compress to much refrigerant at one time. I would first check the main breaker for that outlet before jumping to any conclusions. Then let it cool completely before trying again. If this still does not work, you may need to bring it to a service center.
Jun 30, 2008 | Haier hwr10xc6 Air Conditioner
Frigidaire FAC124 wall/Window Air Conditioner Logo
195 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
