Question about Canon ImageClass D880 Copier
My canon d880 has message that says install cartridge. I have tried different cartridges. still says same message. need help!
  • lnb_bussines Jul 21, 2010
    I LIKE TO KNOW WHICH BOARD DETECTS THE DRUM & TONER CARTRIDGE TELLING THE COPIER THATS ITS THERE. AND PUTS THE MESSAGE ON THE DISPLAY THAT SAYS INSTALL CARTRIGE. OR IS IT A SENSORS. THANK YOU!
  • lnb_bussines Jul 23, 2010
    THANK YOU! YOUR SOLUTION WAS RIGHT on the money. I tried what y0u said and it worked great. simple solution, but it work. thanks again and have a good night. LOU in peru.
    President:
  • 567 Answers
Hi there, you remove the cartridges and clean the place where you remove them from and then put them back in and make sure they are firmly fitted into place.
Posted on Jul 22, 2010
  • Hilton Bristol Jul 23, 2010
    I am please to know your printer is working fine now.
    Thank you for choosing Fixya
  • 503 Answers
There is two cartridges the machine is using-Toner cartridge and Drum cartridge,make sure you have replaced the correct one.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jul 18, 2010
  • 1 more comment
  • lnb_bussines Jul 19, 2010
    my copier takes a L50 cartridge. I took another drum & toner cartridge from another machine and it still does not work. I think it may have some to do with a sensor. please respond.
  • Monika Arora
    Monika Arora Jul 19, 2010
    by using original carts instead of poor designed generic ones.
    Or by answering the lcd-display question if you have changed the cart.
    or by making sure that the plastic nose secures the cart which was placed well into the holder.
    If that doesnt work, the circuit board might be defective.
  • Monika Arora
    Monika Arora Jul 23, 2010
    I hope that your issue is resolved.
How do I fix e07
I assume you have a Canon copier based on the E007 error code. The Fuser fixing film is torn and the Fixing film assembly or the entire fuser should be replaced. Very common issue.......You cannot reset that code without first replacing the part causing the code.
Dec 03, 2014 | Office Equipment & Supplies
Cartridge not installed properly
Need to make sure that is is on there firm and snap in the right way.
Jun 25, 2009 | Canon PIXMA iP1300 Printer
Is there a Mac OSX driver for the Canon ImageCLASS D880?
It's not the same as that at all, and different printers were designed to use the same cartridges, it's not a coincidence.
If it is actually the D880 you're inquiring about, then it's not compatible, because it doesn't "speak" MAC. Therefore, there is obviously no other driver that will work.
May 28, 2009 | Canon ImageClass D880 Copier
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Have the canon d880 having hard time changing the toner cartridge
The main reason for cartridge replacement problems is the locking mechinasim not fully retracting. When you slide the platen to the left and open the door on the right make sure you open it all the way. It should go to a little mor them a 90 degree angle. You should be able to remove easily at this point when putting cartridge back in if you look at the back wall in betwwen the cartridge guides you will see a white plastic circle with a triangle in the center make sure it is flush with the metal if not push the door a little more to the left.
Jan 09, 2009 | Canon imageCLASS D880 All-In-One Laser...
Can't replace cartridge in Canon ImageClass D880
Something is blocking the access, or the clips may be bent or broken
Dec 24, 2008 | Canon imageCLASS D880 All-In-One Laser...
We would like to override the "Replace Cartridge" to print faxes
Try this way, take the cartridge out, shake it side to side 5-6 times, put it back and try to print
Sometime it works, sometime not
Good luck to you
Dec 16, 2008 | Canon imageCLASS D880 All-In-One Laser...
Problem sending & Receiving Fax Imageclass D880 Canon All in one printer
#0018 indicates there was a problem with dialing, but it should show for sending faxes only. Since you can neither send nor receive faxes, and are getting a message saying "no signal", make sure that the phone line is still securely connected to both the L (line) jack on the machine and the phone jack in the wall. If it is, plug another phone into the accessory jack on the machine, and check to see if you are getting a dial tone. It seems like the machine is not able to communicate through the phone line.
Oct 10, 2008 | Canon imageCLASS D880 All-In-One Laser...
Canon image class mf 8170 problem
its mean that change new drum cartridge
Oct 17, 2007 | Canon ImageClass D880 Copier
Canon ImageClass D880 Copier Logo
42 people viewed this question
old marine
old marine
