Question about Samsung HL-S5087W DLP TV
Samsung same DLP same o problem, turning off by itself and wont turn on lamp light blinking with temp light blinking, read many people replaced the lamp to fix the roblem and still have the same problem, complained to samsung they are going to send out tech out of my pocket, what should I expect? I feel im going to get screwed
  • 20 Answers
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Posted on Aug 11, 2011
BUY NEW T V
Posted on Mar 05, 2011
  • krimi Aug 11, 2011
Samsung Mod. HL-4663W turns off by itself. Started later after replacing lamp.
Posted on Jul 22, 2010
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
Nov 16, 2013 | Samsung HL-S5086W 50" HDTV
I replaced the lamp on my Samsung HLS5086WX/XAA DLP set. How do I reset the timer on the lamp?
I have a Samsung DLP HLN617WX/XAA. After turning off by itself, the three indicator lights were blinking... signifying a defective lamp. I've re-seated the old lamp several times with no change. I bought a new lamp and reset the lamp hours through the "service menu" with no change. My television is still turning itself off and still blinking the same indicator lights. What should I look at, next?
Oct 26, 2010 | Samsung Televison & Video
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
I have a Samsung HL56A650 DLP TV. The Standby/Temp and the Timer lights are blinking. It will turn on and then shut off. When it comes on the picture is fine but it only stays on for a few seconds. There...
The description sounds like a protection mode has been activated and the smoke obviously confirms this. Sounds like it will need to be inspected by a service technician and could get expensive
Mar 19, 2010 | Samsung HL56A650 56 in. TV
Why is my 42" dlp tv turns itself off after awhile?
the power supply is not working fine. your tv needs preventive service so that semiconductor, diodes and capacitors are changed on the power supply before it switches off completely on its own.
do it fast
okay
Jan 05, 2010 | Samsung DLP HL-P5663W 56" TV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Aug 30, 2009 | Samsung DLP HL-P5663W 56" TV
My DLP TV shut itself off & won't turn on, help!
The 3 lights on the tv are there to help you diagnose the problem. There should be Timer, Lamp, and Temp. If all 3 are blinking, the LED may be defective. If standby and temp are blinking, it's a problem w/the cooling fan.
Let me know if that helps.
Dec 15, 2008 | Microsoft Xbox 360 Console
Samsung HL-S5087W DLP TV Logo
798 people viewed this question
Jerry Greenberg
Jerry Greenberg
