Question about Garden
How to fix a retractable winding for the start cord on a sthil weed eater. cord is hanging out and will not retract back in.
    President:
  • 1,545 Answers
Have never worked on a Stihl, but it's evident ..you are going to have to remove all the covers to get to the recoil unit itself and when you get there, you will see the problem. Don't know what kind of fasteners Stihl uses on their equipment, but the cheaper manufacturers use TORX screws in their applications.
Posted on Jul 18, 2010
How do i fix a cord not going back in on a craftsman weed eater/blower combo 32cc
The one way clutch could be broken or jammed. Take off the starter for a closer look.
May 10, 2014 | Craftsman Garden
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Weedeater gas blower FLI500E. The pull cord has become jammed. How can I un-jam the rope pull? I have removed the bottom of the blower and can get the rope pulled out, but it will not retract properly or...
You have to find a way to push the starter. It normally gets all stuck due to grease. One push with a screwdriver on the actual starter (The thing the rope turns) should wind the whole cord up. If not, clean it. Alot of oil/chunky-ness gets trapt when your using it.
Apr 27, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
Starter cord pulled out of the housing, it
if it's new take it back should have a one year warrenty on it if yo can't get it done for free get back to me so I can help you you may have a damaged windind head.
Apr 14, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Cord won't retract
The spring is either broken or the catch on the end of it isn't seated, this is a coil spring inside the hub, probaly has to be rewound to gain the tension back
Aug 22, 2009 | Garden
Gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Jul 25, 2009 | Garden
Repalce the pull cord a Craftsman Weed eater 32CC
I have a craftman weed eater model M358.796600 and the pull cord will not retract any more...how do you fix it?
Drew
Jul 02, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
158 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
