Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Brushes won't spin
The brushes on my rug cleaner won't spin
    Problem Solver:
  • 7 Answers
The power wire may be disconnected
take apart the unit at the top (Behind the cleaning fluid container) Inside there is a wire coming up from the motor at the bottom of the unit. This can come unlpugged no longer powering the scrub brushes. Simply slip the wire back on the plug.
To open: remove all visible screws from top half of machine. Remove the rubber mode dial by pulling off, and remove screw behind that. Pull the front off, and the power plugs are located right on the inside of the machine by the mode dial
Posted on Aug 05, 2009
Brush won`t spin on brand new vacuum
Hi! Many of our vacuums include a brushroll shut-off feature that needs to be activated in order for the brushes to spin. The brushroll shut-off pedal is usually located on the right side of the cleaner on the hood. Your instruction manual will show you exactly where your brushroll shut off pedal/button is located if your vacuum has this feature. Also, on many models the brushes will not spin when locked in the upright position. The handle must be reclined for the brushes to spin. Hope this helps!
Jun 13, 2014 | Hoover Vacuums
Brissell proheata 2x doesn't have suction or the red brushes won't rotate on the hand tools?
Check the brushes for hair or some other clogging material and remove it. If the brushes can't spin freely, there is not enough suction power to make them spin.
Sep 17, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The brushes wont spin on my Hoover rug shampooer Model # f7220-950.
try cleaning brush...
if sam problem need replaced turbine part no: 43191009 Turbine & Gear Assem
Nov 04, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover all terrain dual v spin and scrub 12 amps
All of the hoover cleaners use air to spin the brushes the air intake is probably clogged. There is a Little clear window on the top of the machine pull that off and underneath is a little screen clean that out and that should fix your problem. If you need any parts or cleaner for your machine visit
Aug 12, 2008 | Vacuums
Brushes don't spin
Take out the screws from the bottom, there will 2 longer ones, they got into the turbine, turn it upright and take the top cover off. The turbine sits near the front, center, remove the 2 screws on the front of it, remove the hoses, then you can remove the turbine(#23).
Aug 10, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
94 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
