Question about Philips DVP642 DVD Player
My Philips dvd player model DVP642/37 is not working. The stand by/ on button flashes the red light on and off slowly and non of the other buttons respond on the machine or the remote for the dvd player that came with it. I've read the manual and done as it said. I unplugged it for a few seconds then plugged it back in and with out pressing anything the light started flashing again. i first noticed this after I had the machine off with a disk in it and I pressed the eject button first without turning the machine on. This usually just turns the machine back on and pops out the disk.
    Top Expert:
  • Philips Master
  • 76,016 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Posted on Apr 21, 2017
markevans
  • 148 Answers
SOURCE: DVD stuck inside, player won't turn on, standby light does NOT flash
test the capacitor with a meter to make sure it has the value stated on it.
the work on this unit is quickly exceeding its present value, most likely.
consider upgrading to a higher resolution unit if the fix is more expensive in parts and time than a new unit costs.
good luck
mark
Posted on Dec 29, 2007
LarryGilbert
  • 3 Answers
SOURCE: Philips DVD Player Seems Dead
It looks like this problem has been discussed here: "Standby light blinking."
Posted on Apr 21, 2008
SOURCE: DVP642/37 Power light flashing constantly.....won't power on
This origional post has been up since June 2006. The answer(s) about the 1000mf capacitor are right on target and has helped people even up to today (Aug. 26, 2008). It worked for me and the following might help others.
First find the power supply board. It is the one with the power cord attached to one end (make sure you unplug all power first!). This power supply has about nine minature electrolytic capacitors in the output of the supply. There is a large electrolytic near the input (elecrtical cord). Disregard this one and go to the other end of the board. The 1000mf, 10volt component you are looking for is near the middle of the 9 or so capacitors on this end. It will probably be the largest in this group (because it has the highest electrolytic value of the group) and the board surface will have an I.D. number of C316 adjacent to it.
DO NOT ASSUME THAT THE CAPACITOR WILL HAVE ANY SIGN OF A BULDGE, DISCOLORATION, OR ANYTHING THAT WOULD IDENTIFY IT AS A FAILURE! In my case the replacement solved the problem but there was absolutely no signs on, or around the capacitor. After replacing it, I checked the old capacitor with a (ANALOG) multimeter. The test showed leakage across the capacitor. In other words it was still working but had a high resistance path through the capacitor. This is exactly what I expected because when I checked the output voltage of the supply to the other 2 boards, voltage was present but was reading about 1/2 of what it was supposed to. The markings on the front (output) edge of the board indicate a -24 volts between ground (pin 4) and pin 3. Mine was reading approximately -12 to -13 volts.
I hope this will help others. As a matter of interest, this is an electrolytic capacitor and you should notice that the component taken out is marked negative ( - ) near one lead. Be certain to install the new one with the negative lead in the same manner! Also, any replacement you might find with a higher voltage rating should be at least 16 volts but a 200 or 1000 volt rating will work fine. Although, the higher the rating, the larger it will physically be. You probably would not be able to physically install anything over 50volt rating. The 35volt rating seems to be very available and a very good choice. With regard to microfarad (mf) value, 1000mf are very common but a 1200mf to 1500mf in a power supply circuit will work fine. Do not use anything less than 1000mf. Hope this helps others. This is going to contiue for this Phillips product until they all die.
Posted on Aug 26, 2008
  • 3 Answers
Hi Everyone.
I had a more extreme version of this problem, and I hope my fix will help those who had no luck changing the capacitor. The player I worked on had a dimly lit power LED and nothing else. The troublesome C316 that you guys diagnosed was in fact bulging upon inspection. However, I wasn't so lucky. After replacing C316 with a 20000uF 35 Volt I still had no life. Using a Scope and my gut knowledge of fixing literally thousands of switching supplys, I found that Q303, Q304, and Q305 were not oscillating and driving the transformer. I thought Phillips was marginal on the C316's ratings, these transistors are only rated a 600 mw at 150 volts. With C316 leaking so bad, it blew them. I should say, my Cap was really bulging on the stress cracks at the top.
Anyway, this fix gives you a better supply that will charge the bigger and better cap you choose. Q304 and Q305 are 2N5551's. Basic NPN General purpose transistors. I replaced them with TIP41's. Q303 is the PNP compliment of the Oscillator so I used a TIP42. Just be careful with the leads if you need to do this fix. Looking at flat side of the original transistors, the leads are Emitter, Base, Collector. The TIP transistors facing you, heat sink away from you, are Base Collector Emitter. So you have to do some fancy lead bending to fit them in. They will fit, and they do hold their peak-to-peak voltage really stiff when motor operations are being performed (like loading or ejecting a disc).
This was another problem I have seen with this unit in the past. The power supply would cave in under the load of the disc tray opening or closing. Probably because C316 was leaking and I didn't know it.
Anyway, this version of the fix is for extreme cases and it will save you some trouble since I could not find a schematic easily.
Here is another tip: For those who don't have a supply of electrolytic caps lying around, you will find something that will work in an old PC power supply. I always keep these boards in my scrap box for these situations. Just Use a Cap that has a greater voltage and capacitance than the old one. And of course, the same lead configuration helps. Use a big "Hog" soldering iron to heat the solder and gently pull out the one you want.
Good Luck
jplandry@hughes.net for Electro-Lab Corp.
Posted on Sep 13, 2008
SOURCE: philips dvp642/37
check conceting wires between your Tv and Dvd player
check Rca wires if it s good or defective.
Posted on Nov 14, 2008
What to do with red blinking ON/OFF button on philips mci500h 12
Internal Power supply and could be a shorted diode or a relay could be causing the flashing red light. Usually the red light indicates the System is in stand-by mode or not in stand-by. If when you used to turn it off there was a red light though not flashing, then that means it is in stand-by so in that mode your remote works on some older sets work and others it doesn't matter because the remote will always work. Unplug it for a half hour and try it and see if the light stops flashing. Might help to give more clues towards the fix.
May 15, 2014 | Televison & Video
I have a DVP642/37 player and after a power outage, the only thing that it will do is flash a red light on the standby button. None of the other buttons work. When I select the DVD player via TV remote,...
Hello
just unplug the DVD player from AC wall power socket, and lst it be in that state for at least 10 minutes and the replug and see whether it helps you. If not, the power supply inverter board of your DVD player is faulty. some fault are repairable, and some others are not. Anyway, it will be best to replace this board as card basis, rather than get it repair. OK.
Nov 02, 2011 | Philips DVP642 DVD Player
Need codes for a ge remot to work on a philips dvd player
If you can't find a code then you should be able to do it manually with the device pointed at the DVD player. 1. turn on the DVD player 2. press setup on the remote (underneath on/off) till red light stays on then take finger off the button 3. press and quickly release device button (in your case VCR or DVD whatever the remote says) the red indicator blinks off once 4. press the on/off button (up to 300 times) until the DVD player turns off the red light blinks off with each button press 5. press and release enter to install code
This should work! -Joe
Jun 07, 2011 | GE JASRM24912 Remote Control
Player does not turns ON, even power supply is given, red LED emits the light, & no problem in circuit board in player
try to check first the remote control press the stand by button if nothings happen one of the ic in your dvd has a problem.
Oct 14, 2010 | Philips DVD 622 DVD Player
LOOKING FOR HACK CODE AND REMOTE CONTROL MODEL NUMBER I SHOULD USE TO DO THIS
one for all rc 7652 works for this as do many others.
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 000533
4. Hold the magic button until the DVD button flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 001891 (this sets key 1 – the DVD button flashes twice)
8. Hold the magic button until the DVD button flashes twice.
9. Press 994
10. Press Magic Key (don't hold)
11. Press 002552 (this sets key 2 – the DVD button flashes twice)
12. Hold the magic button until the DVD button flashes twice.
13. Press 994
14. Press Magic Key (don't hold)
15. Press 000953 (this sets key 3 – the DVD button flashes twice)
16. Hold the magic button until the DVD button flashes twice.
17. Press 994
18. Press Magic Key (don't hold)
19. Press 002214 (this sets key 4 – the DVD button flashes twice)
20. Hold the magic button until the DVD button flashes twice. .
21. Press 994
22. Press Magic Key (don't hold)
23. Press 000795 (this sets key 5 – the DVD button flashes twice)
Done - the remote is now programmed and ready to use
Quote:
1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed
2. Make sure there isn't a disc in the machine.
3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing)
4. Put the player back into standby with the Sony remote
5. That’s it, the next time you turn on the player it will be region free for DVD playback
I personally dropped the 00 that are marked red and it worked for me but it depends on model of one for all remote.
Jan 31, 2010 | Sony BDP-S360 DVD Player
Player won't open. how do we reset?
my dvd player is stand on the red light when i insert the dvd the dvd will hand after few seconds what is the problem please solved my problem
Jan 04, 2010 | Philips DVP642 DVD Player
Dvd code
Try preforming an automatic code search:
1) Make sure the device is on.
2) Hold down the DVD button and the power button simultaneously until the red light stays on solid.
3) Then press the power button - it will flash one time - keep pressing slowly, letting it flash until the device turns off.
4) As soon as the device turns off, press the stop button
If your the remote does not power the device off after cycling through all the codes - You will know this when the power button blinks and deluminates - then your "universal" remote will not work with the DVD player.
The best of luck to you!
Sep 18, 2008 | Televison & Video
Code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Aug 30, 2008 | Apex Digital ADV3800 DVD Player/VCR
Lost codes
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | Philips Magnavox Learning Universal Remote
Philips universal Code
hope this may help;
Regards,
VOTIT
Aug 13, 2008 | Philips Magnavox Learning Universal Remote
Philips DVP642 DVD Player Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
