Question about Compaq Presario 700 470024-192 Notebook
My Compaq laptop keyboard seems to be stuck in ALT mode. All the keys which have an alternate character in the upper right corner, will only type those characters. For example, the "m" key will only type "0" and the "j" key will only type "3". I can't get it out of ALT mode.
    Problem Solver:
  • 18 Answers
Never ran into this problem myself but a friend of mine has. He said what fixed his what holding Fn + Num Lock and it remedied his problem.
Unless your key is stuck/broken you can also try a can of air and try to blow it out and or pull the key and make sure its not stuck down.
But deff try the holding Fn + Num Lock method first.
Posted on Jul 18, 2010
Brilliant, worked first time thanks (fn num lock)
Posted on Apr 06, 2011
How to use Alt Car key?
I am guessing the Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. On these models, it seems the alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
hth!
Aug 13, 2010 | Sony VAIO VGN-FS640W Notebook
How do i access the characters/symbols
you need to press alt and insert ascii char code for the marks.
Oct 17, 2008 | GE USB Retractable Number Pad HO98462
Tip
Some letter key is not working on keyboard???
if any of the key on the keyboard is not working, you can use an alternate for time being. This is regarding ASCII. There are ASCII codes for every character on the keyboard. A - 65,B - 66........... So on a - 97, b - 98...........So on
Use these codes by pressing and holding Alt key on the keyboard. In order to type b character. Press and hold Alt key and type 66 from the numpad at the right side of the keyboard.
on Apr 17, 2010 | Computers & Internet
Periodically the keyboard gets changed to the "green" keys.
It's possible that the 'ALT GR' ("alternate graphic") key, just to the right of the space-bar, is "stuck" in the "down" position, and thus you get the "alternate" characters.
Jan 07, 2010 | Acer Aspire 5735 Notebook
Keyboard
one of 3 things seems likely: 1) you have a key on your motherboard that is stuck. tap the heck out of your Fn key, as well as all your Ctrl, Alt, and Shift keys. 2) your computer (operating system) has switched keyboard modes from standard western world american english setting to some other style. See if you can use your mouse to checkout keyboard settings in the control panel. 3) your keyboard is toast. hit dell/ebay for a replacement keyboard (the cheapest part of a laptop).
Oct 05, 2009 | Computers & Internet
My Dell Vostro 1000 laptop keyboard (right side) keys are not typing what I type. It is like they are out of sync. Can you help? (I am currently using a different computer to type this.
Num Lk will cause the keys on the right-hand side of your keyboard to display the alternate characters printed in blue. Just press the Num Lk key--it's the fifth key from the top right corner of your keyboard--to deselect, and your problem will vanish.
Sep 14, 2009 | Dell Vostro 1000 Notebook
What is the fastest way of typing an é? I have been going through start, accessories, system tools, character map, copying, pasting, but there must be a quicker way?
If you are doing this on a laptop then you are stuck. About the only way is to use character map and copy as you have been or to try to program a quick start key to paste it.
The ALT-0233 is meant to be used on a 101 key pc type keyboard and the laptops do not use the same layout. Your only options would be to use a external keyboard instead of the built in one. I've tried a few things such as the built in numpad using function and an external numpad but neither worked for me. Your laptop may be different so it worth trying.
Sep 01, 2009 | Acer NSK8458AN Keyboard
Blue characters on the keyboard when I type
It is a combination of key known as "Function" (Fn, for short). You have to press it and hold while pressing other keys showing the blue letters on it. The most common use is to make a virtual Numerical Keypad on laptops, so you can perform calculations. To be back to normal mode, you need to press FN+F8 (or the key with the Calculator icon).
May 28, 2009 | Compaq Presario R3000 Notebook
How do I use the "AltCar" on my labtop?
Okay, I know this is an old question but when i searched for the same problem recently, it was the nearest I could find. So in case others are having the same problem:
The Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. The alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
hth!
Dec 19, 2008 | Sony VAIO VGN-FS640W Notebook
Compaq Presario 700 470024-192 Notebook Logo
1,132 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
