Question about Logitech Cordless Mouse
Hi, my mouse doesn't seem to be working. It is a wireless mouse, i have unplugged the connector usb cable and replugged it in and have reset the mouse yet it is still not connecting. What should i do?
  • 6 Answers
SOURCE: wireless mouse doesn't work
This problem was happening on my system but i managed to fix it easily! What has happened is your itouch software has become corrupt so it will only recognise your keyboard thus the usb connection. You will need to download/install off disc onto your computer again but do NOT go to uninstall program manager on windows as it will not appear there because even though you can access the itouch configuration panel, the database is corrupt and the administrative system will not recognise this. Just download/install via disc and it will just install with no alerts unlike most programs which will recognise the program is already installed onto the system. Once the setup is 92% it will freeze for a second then the found new hardware window will appear on screen go through that process and your mouse is back to normal and your keyboard will work via itouch software.
(Please note that this will only work on windows)
Posted on Jan 02, 2009
skotkolr
  • 558 Answers
SOURCE: resetting a wireless mouse
the usb connection and the mouse should have a button both need to be pushed usually the usb connector first then the mouse, or shut down the computer then restart. let me know if this helps.
Posted on Apr 05, 2009
proJekttaLon
  • 91 Answers
SOURCE: After accidently unplugging the mouse's usb reciever, the pointer froze on the monitor screen.
Try plugging in a standard mouse and changing the settings to it, Then re-boot. Once booted try plugging the TrackMan Wheel back in and changing the mouse settings back to it and re-boot again. Let me know what that does for ya.
Posted on May 24, 2009
leecom72
  • 4806 Answers
SOURCE: wireless mouse wont connect.
Hi there.
Some wireless mice seem to go into some kind of sleep mode, in other words if you leave them for an amount of time they disconnect, the way to reconnect is to right click while moving the mouse.
Also check to make sure that the batteries in the mouse are seated properly.
Good luck
Posted on Jun 01, 2009
  • 29 Answers
SOURCE: Logitech wireless usb mouse not working
just see the bottom side of the receiver. you will fin a hole. clean the hole by blowing in the air. if this didnt work lust open the receiver(be careful not to break it, use plastic card or credit card on the side to open the hooks) and put 2 drops of white petrol on that part and leave it for one minute,then wipe it with cotton.
cheers...
i was also having the same problem but solved it with the help of logitech tchnical department...
sagar
Posted on Jul 29, 2009
Suddenly my mouse stopped working and the red light stop on it as well. What shall I do?
dear mario
it seems to be a problem with the mouse cable.
shutdown your computer and remove the mouse cable and replug the mouse again.
now start your computer and see is it working now
if no , then if you have a USB mouse try using it on another USB port
else you have to purchase a new mouse and plug it in.
thanks
Gagan
Mar 17, 2011 | Ideazon Reaper ZMS 1000 Mouse
I put in new batteries ! how do I reboot it
You can unplug the usb cable and replug it on the computer(the one for the keyboard and mouse) if that does not do the trick. On the wireless broadcaster there is a connect button to sync up the keyboard and mouse, press it (some models need it to be pressed for 3-5 secs) then press the same buttons under the keyboard and mouse. This should sync the mouse and keyboard and you are on your way!
Mar 07, 2011 | Micro Innovations Wireless...
I need to be able to get my new optical HP mouse working with my toshiba laptop
hi is it wireless optical mouse? you might need to install the driver. if it's wired just plugged it in,if it still does not work, unplug the power cable for a minute and replug back everything in
Jan 14, 2011 | HP Wireless Optical Mouse
Wireless mouse does not work after changing batteries.it always has in the past The Dell computer and mouse is probably 8 years old but has always worked.
Try moving the mouse receivers usb plug in to another port. Unplug any new devices and restart computer. Then replug in any new usb devices.
If still not working.......
Look at Office Depot and other office stores for a replacement wireless mouse. I have seen them as low a $9.99 on up. You might even want to upgrade and get a wireless mouse and keyboard set.
Mar 08, 2010 | Logitech WIRELESS OPTICAL CORDLESS MOUSE...
My wireless mouse will not work, I forget how to 're'-pair it. It was functioning normally before i left home for a couple of days. Both the mouse and the other part (that goes into the usb port) are...
1. Try unplugging usb device and replugging in (I'm sure you already did that) LOL
2. Uninstall device driver
3. After uninstall plug in USB device
see if that works
Nov 14, 2009 | BenQ M310 Wireless Mini Optical Mouse
There isn't connection between the wireless mouse and laptop
First, reload the softwear than came with the mouse. Then, check the cable connections from the receiver to your laptop. If USB, then unplug and replug, if PS-2, unplug, replug, make sure the cord(s) are seated fully in the laptop. Then change the battery in the mouse, push the connect button on the mouse, and you should be back in business. I have Logitech wireless keyboard and laptop and have not had any problems after reinstalling and checking batteries and initiating the reconnect button. You will see a small window on your screen saying the mouse is connected on Channel 1 or 2. I hope this will help you.
Sep 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
The mouse do not work after I restart my computer
check battery. press reset button both usb and mouse.
May 31, 2009 | Gear Head Wireless Optical Tilt Wheel...
Resetting a wireless mouse
Mar 31, 2009 | Logitech Cordless Mouse
Mouse is not working
Right Click on My computer-Properties-hardware-device manager-Expand USB Controllers- LOOK FOR ANY UNKNOWN DEVICE OR YOUR MOUSE NAME. Right click on it and uninstall it. Unplug and Replug ur mousr.. it should work..
Its the problem with USB drivers we just need to uninsall n reinstall it.
Feb 04, 2009 | A4tech Wireless Optical Mouse rfsop-48
Hi, this might be a similier problem,but i can't the soulution
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jul 07, 2008 | Targus Wireless Optical Notebook Mouse...
Logitech Cordless Mouse Logo
350 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
