Question about Olympus VN6200 Digital Voice Recorder
Unable to record
Bought Olympus VN-6200 PC digital voice recorder .Was working OK.After I changed the battery recently when I tried to record I am Unable to record .Says "input blocked". How do I get it to record.
I was using my voice Digital Recorder VN-6200PC. I was recording a my lesson when the screen shows formatting, I immediately took out the battery as not to lose any data, because I was taping and it began to format and I lose the data I was recording. So this time I remove the battery. However when I put back the battery it began to say imput blocked. Please help?
Posted on Oct 05, 2010
    Problem Solver:
  • 11 Answers
I got this same message on my VN7000PC that I got in LIDL. The message appeared when I tried to record. I could not get it to go away. At the time I just happened to have 5 files in Folder A with lock on. I tried to remove the file locks. I got the same message "Input Blocked". That was a clue. Maybe it had something to do with the internal 1GB drive. I formatted the drive. The message disappeared and now I can record again.
Posted on Sep 14, 2011
  • Anne-Marie Emanuelli
    Anne-Marie Emanuelli Nov 30, 2013
    I can't reformat because it says the drive is "write protected". I can't seem to do anything because of the "input blocked" message.
Is the vn6000 or vn 6200 compatible with windows 7 ?
The Olympus VN-6000 will likely not have a PC/Mac USB connector cable, so, if you want to transfer files to your computer you would be better off looking at the Olympus VN-6200PC.
Sep 14, 2011 | Olympus VN6000 Digital Voice Recorder
I've purched the Olympus digital recorder VN-100 VN-2000 a few years ago. I've never really used it. But i recently need to..and for some reason it cant record. Everytime I push the REC button ,the red...
take out the batteries , push the reset button, then put batteries back and try again.
If still not working properly , then it probably should go back to Olympus, if you bought it a few years ago , its probably out of warranty.
You can buy a newer model like the vn-6200-pc , which has way more memory and more features for much much less then it will cost to repair the vn-100 or vn-2000 , f
Dec 25, 2010 | Olympus VN-1000 Digital Voice Recorder
Screen shows ERR. I changed batteries and tried
You're right..This happens often when one changes the battery.Here's what to do :
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in ALL the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again.
Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
Feb 01, 2010 | Olympus VN-4100PC Digital Voice Recorder
File Recovery from Olympus VN-6200 PC voice recorder
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your recorder to another PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Good Luck!
Jan 10, 2010 | Olympus DS-40 Digital Voice Recorder
We have an Olympus Digital Voice Recorder VN-3100PC and it will not power up with new batteries installed correctly. When a power line is connected into the "PCI/F" connector it flashes "CHK" then stays...
when the recorder is plugged into the pc, it will flash pc and be powered by the pc... but when the recorder is not plugged in, then the batteries are needed to power on
Jan 18, 2009 | Olympus VN-3100PC Digital Voice Recorder
How do I get back deleted voice files from my Olympus VN-3100PC digital recorder?
Unfortunately because the device has flash memory the voice files once deleted are unable to be retrieved. You may try to google search for companies that specialize in flash memory recovery but it is a very expensive process.
Dec 09, 2008 | Olympus VN-3100PC Digital Voice Recorder
Recherche pilote pour vn-4100pc pour vista premium
Purchased an Olympus VN-4100PV digital voice recorder a couple of months ago at Radioshack. (no software came with it)
Recently purchased new PC with Vista 64-bit. Recorder will not work. Called Olympus today, 12-3-08 and was told no driver is going to be issued to remedy this situation, thus rendering my device useless.
Thanks for nothing Olympus product support.
Nov 18, 2008 | Olympus VN-4100PC Digital Voice Recorder
Unable to transfer folders from the recorder to the pc
I am using Digital Wave Player software together with VN-3100PC on Windows XP, it has a limiting functionality, but it works
Oct 20, 2007 | Olympus VN-3100PC Digital Voice Recorder
Olympus VN6200 Digital Voice Recorder Logo
857 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
