Question about RCA D52W19 52" Rear Projection Television
CRK820TAL1 manual I lost CRK820TAL1 (remote control) owner's manual, then i need it for controlling my L50000 RCA 50" rear projection tv.
5 Suggested Answers
  • 1030 Answers
SOURCE: OWNERS MANUAL FOR RCA
owners manuals or user guides are availble online at rca.com
Posted on Jan 18, 2008
have no pic light blinks green for 3 seconds but will not power up
Posted on Oct 05, 2008
SOURCE: rca tv
We had the same problem, your power supply in the tv went out. Call a mobile tv repair person and they can come and check it and order the part. It takes about a week. It costs about $200 but fixes the problem immediately.
Good Luck
wonderwoman364
Posted on Jan 08, 2009
joboo1
  • 257 Answers
SOURCE: My RCA 50'' DLP Rear Projection TV will not turn on
Hi, This could be several things as the power goes everywhere. Long distance troubleshooting so hang in there. First try a cold reboot by unplugging and replugging after 30 minutes. If nothing check P1 on the light engine for the following voltages: pin 2 5vdc, pin 3 3.3vdc, pin 9 3.3vdc, pin 12 12vdc. If any of these are not good it is the formatter board. If all are good, does the color wheel spin at all. If this is OK then check J4 on the light engine, the ballast enable line should be 0 vdc in stby, .5 vdc at turn on, and 2.5 to 3.25 vdc in run. If good, is the light engine trying to fire the lamp? If not, inspect the J4 connector and the lamp power supply, If they look OK then the lamp ballast is probably bad. This will give you something to do for now, Good Luck!
Posted on Feb 15, 2009
Need a new replacement bulb for a m50wh725, where do i find it?
Go to Encompass Electronics 1-800-638-3328 or Mats Electronics 1-800-628-1118
Oct 04, 2009 | RCA L50000 50" Rear Projection Television
RCA 50" Projection TV
When you have picture, look a the back of the TV and see where light is eminationg from through grill or vent of some sort. When you lose the picture, see if you still have light. If you do, then you don't have a ballast problem you have some sort of Light Engine problem and that will be an expensive fix, but not as expensive as if you have to replace the ballast that drives the back light.
Sep 21, 2009 | RCA L50000 50" Rear Projection Television
Remote control not responding to tv
You need to program the remote to work with the TV. And I hate to point you this way, but I've looked around for the manual on this remote, and can't find it, so, go to the Toshiba website and email Customer service that you have lost your manual for the remote. See if they will email you one. I bet they will.
Jan 30, 2009 | Toshiba 42H81 42" Rear Projection...
50' rca projection tv
your high voltage splitter is probably bad, or you high voltage flyback transformer (deflection board). not sure of your model #, is it correct? It may be a lamp but you shouldnt smell burning. You can unplug and let it discharge and find where the burnt up parts are to find your problem. Follow your nose, it always knows!
High-voltage can hurt/kill you.. be very careful
Jan 23, 2009 | RCA L50000 50" Rear Projection Television
Zoom control
Use the menu key on the set it has a size selection in the menu set it on widescreen or 16:9 I suggest buying a new original remote as even a new RCA universal remote may not have the ZOOM or aspect control on them.
Aug 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
PROJECTION TV
WE did the same thing it will eventually dry up
May 03, 2008 | RCA L50000 50" Rear Projection Television
Rca big button universal remote
159,013,012,182,054.Trata con estos.
Mar 15, 2008 | RCA Universal Remote Control
Rca m50wh725 rear projection tv.
It has gone into protection mode. This is caused when a short circuit is detected by the power management system inside the tv. Try a hard reset: Unplug the power cord for a full 4 hours; then try it again and see if it will clear the protection fault and reset it. If the reset does not help you will need to have a tech look at the set and take voltage measurements inside to determine which section of the tv has failed and what components will need replacement. The cost of repair is always over $200 and could be much more, depending on the specific parts that need replacing. If the ICs have burned out the repair is around $400. The flashing of the standby light may mean something, but I do not know the diagnostic code RCA is using; most RCA models do not have any diagnostic blink codes in the set. Hope this helps. Let me know if I can help further.
Jul 06, 2007 | RCA L50000 50" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
142 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
