Question about Lexmark 83 Color Ink Cartridge (Twin Pack) Printer
I have no software drive for printer to work on my computer
  • 94 Answers
If you specify the printer type then you can go to the manufacturers website and download the drivers based on the operating system installed on your computer.
Posted on Jul 19, 2010
Lexmark 7170 all in one scanner not working - printer and copier is working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If you're scanning documents for editing, make sure that the Lexmark OCR scan software is installed on your computer. The OCR scan software is only available on the installation disc that came with your printer (no downloadable version). If you have the disc, simply insert the disc into your computer hard drive and execute the file.
Dec 22, 2011 | Office Equipment & Supplies
Lost software to printer
You can download software from HP website, I will give you the link
Aug 26, 2008 | HP Officejet 5610 All-In-One InkJet...
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From
your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Sep 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I want the software download to my computer so i can use my printer i do not have a cd drive
just check for your printer brand and model. Go to that brand website and search for that model software. you will get it. download and install then your printer works.
Jul 23, 2011 | Office Equipment & Supplies
My hp laserjet 1200 series keeps running test pages, how do I reset it?
Follow these steps:
Reset your printer if you are having communication problems with the computer. To do so, press the "Power" button to turn off the printer. Wait a few seconds and then power it back on.
Power off the printer again if you are still running into problems and disconnect the power cable from the AC power. Wait a few seconds and reconnect the power cable. Power on the printer. This simple procedure resets the printer back to the default factory settings. Move to the next step if the reset does not work.
Disconnect the USB cable from the printer. Insert the printer software installation CD into the CD-ROM drive on your computer and wait for it to automatically launch. Click the Windows "Start" button if it does not launch and click "My Computer. Right-click the CD-ROM drive with the disk and click "Autoplay to run the CD.
Select "Setup" on the CD and select "Remove HP printer. The printer software and drivers are removed from your computer.
5
Reconnect the USB cable to the printer. The installation disc automatically recognizes it and begins reinstalling the software and drivers.
6
Print a test sheet to verify that the printer is now working. You can print a test sheet using a word processing application (e.g. Microsoft Word) or using the Internet.
Oct 26, 2010 | Office Equipment & Supplies
I have a dell with windows vista and it will not except a printer.we tryed two printer put new usb cable to computer and printer it says not communicating with printer. printers work my daughter put them...
You may need to update windows
and the chipset software
if you have a thumb drive try it to see if it works on the computer
if not update windows and all drivers
Good Luck
Happy Computing
Jan 09, 2010 | Dell Inspiron 530 Desktop Computer
How can i install hp inkjet f2180 printer without disc drive? am completely computer illiterate! please help, thanx
hi
unplug the printer from the computer usb port.
you can download the software for it from here http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=vn&product=3177562&lang=en& just click on the long link.
Select if you have Vista or XP (take the Xp or vista, or older, not the x64 verions)
download the full feature software and driver. which will include everything the cd would.
install the software and plug in the printer when it asks you.
Sep 11, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Must instal software to computer hardrive no cd
You can install your X1240 All-on-One by following follwing these steps
1) Insert your X1240 installation Disk in the CD drive. Install the software by following the instructions on the screen.
2)Connect the USB cable of the printer to your computers USB port. Your printer will be detected and Ready to work.
3) If you have Windows Vista , download the upgrade drivers from Lexmark Website and intall them, then connect your X1240.
Apr 18, 2009 | Lexmark X1240 All-In-One InkJet Printer
Printer not recognized
make sure you installed the software properly..sometimes some software requires you connect the printer first then install software...other times you install software first then install printer....make sure the settings are set up the same on the printer and computer....make sure all connections are secure..check owners manual...
Apr 16, 2009 | HP DeskJet 1280 InkJet Printer
Cannot reinstall
I had a friend that had this problem.  Disconnect the printer and shut it off.  Go to add/remove programs and remove all software related with it.  Restart your computer.  Put the cd in the drive and install all the software.  DO NOT connect the printer until the software tells you to or says that it can not find the printer.  First plug the USB to the printer and to your computer.  Then press the power button on the printer.  If a found new hardware box pops up, press cancel.  Continue with installing the software.  Restart your computer when you are done.  This worked for my friend.  People do make the common mistake of not unplugging the printer when reinstalling software.  Hope it helps.
Feb 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
Lexmark 83 Color Ink Cartridge (Twin Pack) Printer Logo
15 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
