Question about Vizio GV42L 42 in. LCD Television
How can i fix the volume on my Vizio. The volume will be on a hundred however you can hardly hear it..Unless that is you change to a different mode and then go back to tv..then you can hear it.
4 Suggested Answers
jan mczeal
  • 632 Answers
SOURCE: DirecTV remote won't work unless we are within 6
Replace remote battery with a new one. It may not be transmitting enough power to work more than 6 feet from the TV.
Posted on Oct 30, 2009
electronick
  • 505 Answers
SOURCE: on my vizio tv i have to turn the volume to max
your volume may be turned down on your cable box or satelite box. if this is so, a dvd should be loud, but cable/sat quite.
go into your settings, then find the audio settings
find the audio output setting, and put it to "fixed" instead of variable
or push "cable" and then try to turn up the volume on your cable remote. .
it may be "fixed" to tv.
this is usually the cause..
it could be your tvs audio amp or processing, but not as likely (main board bad)
let me know if you need further assistance.
Posted on Jun 06, 2010
SOURCE: I just bought the Vizio E421VA and I am
we have had the same problem and I suggested to Hubby that we had better return it soon. He did some research and we are trying this: use the TV remote and press the center button "Select", Choose Audio, Make sure True Volume is set to On. I've only been watching for an hour but it very well may have solved the problem. Hope it works.
Posted on Feb 26, 2011
Turned up full volume u can only just hear sound if ear right to it was working fine then the volume just ******** out
It could be the mic plug. uniden is known for the issue where the wires inside the mix plug break at the solder joints.
When the RX wire breaks, you will loose receive because the radio will not go into receive mode. But you can usually hear it ever so slightly if you crank the volume.
Other issue that may cause this. No radio activity, (unless you hear radio activity low and not static)
poor feed line or antenna.
I would try a different mic that is known to work.
Aug 11, 2012 | Radio Communications
I just bought the Vizio E421VA and I am contemplating take it back. The volume levels are horribly inconsistent. On some channels I can have the volume level at 2 and its loud, on others you put it to 20...
Feb 07, 2011 | Vizio E421VA 42 in. LCD TV
Vizio tv hdtv lcd changes channels and makes the volume go up and down on its own.
I called Vizio when my TV acted up and was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in.
Hope this works for you, if it does, let me know by coming back and voting. Thanks!
Sep 11, 2010 | Vizio L32 32 in. LCD HDTV
Ive had my vizio for 4 months and just recently the volume on the same 4 channels slowly decreases til you cant hear much. With a change of the channel or a commercial the volume returns. Recently moved to...
First - connect DVD player preferably to the same input (unless you are using RF connector) and make sure that same issue does happens while you are watching movies. If it does - main board in your TV have to be replaced. If it does not - it still cable signal problem.
Aug 11, 2010 | Vizio SV421XVT 42 in. LCD TV
On my vizio tv i have to turn the volume to max and its still hard to hear all the cables are right. thankyou
Jun 06, 2010 | Vizio VX37L Television
I can't hear anyone on the phone, unless it's on loud speaker
sound like the earphone has gone down, some people experience this problem when turning upthe volume within service mode and this damages the speaker, the loud speaker and earpiece are different modules. You may be able to find one on ebay and fix it or takeit to your local shop for repair or if its under warranty send it back to samsung
Dec 03, 2009 | Samsung SGH-G600 Cellular Phone
Vizio 37 inch channels and volume changing on its own
The circuit or integrated circuit being controlled has likely failed. You might try 'resetting' it by pulling the AC plug overnight. If that has no effect, a repair is unavoidable. This model seems to be developing a number of different problems.
Jun 14, 2009 | Vizio L37 Television
Vizio TV low volume
Hi, had this problem and called my cable company who came out and changed some setting ...and now its great.
Apr 17, 2009 | V, Inc. VIZIO RP56 Rear Projection...
Vizio Volume Control
I am sure you did this but recheck your audio menu on all your inputs. I have found that cables can go bad so make sure they are in good shape. Are you haveing the problems with all your inputs dvd, cable (direct cable or a cable box) whatever? It is hard to affect the audio by just moving the set. I am hoping that you changed something or the cables went bad that would be the easy solution.
Good Luck!
Aug 04, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Sound of My Vizio L37
I know thier are some hidden sound settings in the menu if you hit your menu key on your remote [or the one on the side of your tv],then goto to the tv and press both the channel up and down buttons simultaneously. You will see a factor menu, try changing the sound settings in there.
Aug 16, 2007 | Vizio L37 Television
Vizio GV42L 42 in. LCD Television Logo
537 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
