Question about Samsung PS42D5S 42 in. EDTV-Ready Plasma Television
Samsung ps42d5sd digital TV no picture, sound ok
Hi, my samsung ps42d5sd works fine. I tried to use the digital tv option for first time and it picked up a few channels but only plays sound, picture blank. I am in Ireland - is the digital coding ok?
SOURCE: Samsung LE46M5 46 in" LCD TV
had same problem same amount of time sent it away came back as a dry solder joint on board cn701
Posted on Mar 22, 2008
  • 4 Answers
SOURCE: Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Posted on Jun 10, 2008
ltfrc
  • 227 Answers
SOURCE: problem with tuning digital channel
I would believe from what you said, you have solved your problem. You will need a UHF antenna to receive the signal. Walmart or Radio Shack has a great amplified antenna that will work for you.
Mike
Posted on Mar 23, 2009
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
  • 30 Answers
SOURCE: Blank Screen but sound works on samsung HPS-S5053
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Posted on Jul 14, 2009
Why does my Samsung LED TV now have a permanent blue hue to its picture?
The t con board digitizes your picture and is responsible for anything you see on the screen including any and all anomalies. I would go that route TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2017 | Samsung Televison & Video
In Samsung tv complaint<br/>in first time tv working in normal and after sometime picture is blinking and slowly no pictre. that time sound is also ok.<br/>after that am am change the capa
Check its solder terminal at the CRT board [Filament voltage]. It sounds like the filament do not glow after some time due to a loose contact at the CRT base connector sockets. Check it.
If this does not help, check the ABL circuit for any open resistor.
Oct 25, 2014 | Televison & Video
Audio with Digital audio cable from TV (HDMI doesn't pass sound)
For hdmi audio transfer, ur TV should have to hdmi arc enable option,
Or check with TV optical option,
If no more optical and hdmi arc option in ur TV, then no more options
U have to connect analogue only..
Dec 17, 2017 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
Tv got picture but no sound tried all connections all ok
Hi sound like digital board gone.There is another possibility of bad connection or lost connection between main board and digital board.Hope that helps.
Sep 15, 2012 | Samsung Televison & Video
Samsung plasma cable problem
your digital or anolog board is bad needs replaced can find on ebay if you can get part #
Jan 23, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
Samsung PS42D5S 42 in. EDTV-Ready Plasma Television Logo
216 people viewed this question
Jerry Greenberg
Jerry Greenberg
