Question about Zenith D61W25 61" Rear Projection Television
Zenith D61W25 shut off after 1-2 mins
Pick up this tv but when i got it home it comes on for 1-2 mins then a little pop and its off can be turned back on with 2 pushes on the power button off again in1-2 mins thanks for any help
  • 2 more comments
  • bakerbuilt Apr 22, 2008
    stays up to 5 mins
    seems to happen each time
    no it was a used tv may have had this problem before i move it but was told it was in good condition
  • bakerbuilt Apr 23, 2008
    OK got home late today remove cover front and back saw no obvios hot spots . so i held the on button without power for a while then powered it up and turn it on with covers still open . left it on approx 1 hr no problem turn it off and back on no problems . Not sure if the results are from sitting ,open covers (less heat) or flea power . will test tomarrow for longer before closing back up and keep you posted
  • 3,037 Answers
Is this a brand new tv?
The pop sound I would think is a lamp but does it happen each time or just the first time.
Please let me know so I can further figure this out.
Thank you for using Fixya
Posted on Apr 22, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 22, 2008
    Alright then it probably is the CRTs which will need to be replaced. Possibly some fluid leaked onto them, please let me know if you need any more help but basically if you replace them, it should be good to go.
  • Benjamin Patri
    Benjamin Patri Apr 23, 2008
    so did you leave unplugged while you were gone to try a hard reset?
    Even if you did that, it may only be temporary and then you should check the CRTs if everything works now but the problem comes up again.
    Please keep me updated, thanks
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
    Genius:
  • 1,142 Answers
Please try a hard reset
  • 1 more comment
  • Maanita Chadha
    Maanita Chadha Apr 22, 2008
    Try to unplug the power cable first
  • Maanita Chadha
    leave it turned off and then try doing a flea power by not connecting the power source to the tv and then try to turn on by pushing the power button by holding it for a atleast 40 seconds this will release the static power from the system.
    then turn it back on and tell me the status.
  • Maanita Chadha
    If you have sound and no picture you either do not have any high
    voltage, the CRT emitters are not powering up or there is no video
    drive to the crts. A long shot would be the brightness is turned down
    but unlikely. The most likely problem is no high voltage. Odds are the
    Horizontal Output Transistor is open. This is easy to check with a vom
    if you are familiar with TVs. If not have a professional do it. TVs are
    dangerous and complicated. If the HOT is open it will need to be
    replaced along with either/and the flyback and HV divider block. If the
    Horizontal Output is ok the problem could be just about anywhere. First
    you need to make sure that all necessary voltages are present and
    correct. After that you need to determine which circuit or section is
    not working. At this point the sound is the only thing you know works.
    Good Luck
My Zenith 52 inch flat screen will automatically shut off after 1-2 mins of turning it on... why?
some tvs have a menu where you can controll that there should be a menu button on your remote try doing that and switching the automatic shutoff to off
Feb 22, 2013 | Zenith Televison & Video
Zenith z56dc1d dlp tv picture works for about 1 minute then starts shaking and tv shuts off
You may want to get it in a rather warm room and or remove rear cover and use a hairdryer to warm everything up inside the Cabinet--with rear cover off look to see if the fans are dirty etc and if they all come on, if a DLP especially look at the lamp itself and the fan that cools it.
Dec 18, 2012 | Zenith Televison & Video
Zenith P42W22H: Accidently turned on stereo while TV was on. Speaker system provides sound for both Units. Stereo popped with power error. TV Popped and went off. I shut down power to both. The Stereo...
Go to this Website Encompass Parts Distrubtion and type in your Model# Look for Audio output IC
1-800-638-3328 and try Zenith Exchange Moduels
1-800-632-6637
Jan 14, 2010 | Televison & Video
My tv is blurry, showing green and red waves...zenith d61w25
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2009 | Zenith D61W25 61" Rear Projection...
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
My Zenith TV stopped working when plugged in the little red light comes on but nothing else happens.
DESOLDER CONVERGENCE IC'S TURN SET ON IF IT COMES ON W/BAD PICT 1 OR BOTH IC'S WERE SHORTED
Apr 12, 2009 | Zenith A56M91W 56" Rear Projection...
Zenith projection tv
Bad Light engine cost was 1900.00 sure it is cheaper now.call UED 1-800-648-6657 for replacement cost.
Oct 12, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith D60WLCD Repair
Go to the Zenith repair site. This has been resolved in a lawsuit. Zenith will fix it free of charge through 7/1/2010. The shop just picked my up to replace the light engine free of charge. Call 1-800-228-1757, have your model number and serial number, and where you purchased it. Here's the neat thing-the question I asked is "have they fixed the problem with the light engine, or is it going to keep going bad?" If happens again (blue lines/spots) before 7/1/2010, they'll replace the TV with a new and different TV of equal value!
Sep 21, 2008 | Zenith D60WLCD 60" Rear Projection...
Picture Greatly distorted all of a sudden by many yellow lines
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jul 07, 2008 | Zenith D61W25 61" Rear Projection...
Zenith D61W25 61" Rear Projection Television Logo
65 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
