Disc is not being read it will not spin - Televison & Video
    Genius:
  • 3,422 Answers
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
Please don't forget to rate the solution.
Posted on Apr 21, 2008
  • 1,183 Answers
Its mostly caused by a faulty head.
If you could specify the model and make of the player , i could provide you with more assitance
Thanks
Mandeep
Won't read regular dvd's
I think local disc cannot read your DVD. Put quality disc into your DVD.
Feb 21, 2014 | LG BD610 BRay Disc Player
Tip
Player reading invalid disc and disc is not spinning
My dual screen dvd player was reading invalid disc and disc was not spinning. Took player completely apart and white gears had dirt in them. This was preventing the player from spinning. Used dust remover and cleaned the whole inside and now it works great.
on Sep 01, 2008 | Durabrand DUR7 Portable DVD Player
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
No disk message
Hello
Check it with a standard company burned disc. if it does not read it, make sure that either the disc does not spins inside, or the laser pickup unit is faulty. Just open the top cover of the set, and insert the disc, see whether it spins at high speed at first and then slows down. if the disc do not spind, the sled motor is faulty. If the disc spins, and still the player do not read disc, the laser pickup unit should be repalced.
Feb 27, 2012 | Samsung DVD-E235 DVD Player
Ps3 not spinning disc, replaced spindle motor, did not fix. Please help
Hi there, this is because the actual laser needs replacing, not the disc spinner motor. With the PS3 the laser reads the disc data type, whether it be a DVD, game , audio cd or blu ray movie. It then spins the disc up to the required read speed. When the laser is faulty is cannot read the disc type so will not spin at all.
Hope this helps
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Wont play
If its not a power problem, notice that the servo motor is spinning or trying to spin with a disc in the tray.
-listen carefully for a high pitch or whinning sound of the motor.
-do you have a reading on the screen? No disc or reading disc?
One of the above can be:
1- a defective laser (it wont illuminate)
2- a broken flat cable to the laser (you wont hear clicking sound when reading)
3- a bad servo motor that can not reach its speed to read the disc (has to spin at a very high speed)
Hope you can solve the problem, succes
Aug 27, 2010 | Apex Digital Televison & Video
Disc read thing (PLZ HELP!)
If you find out that it is spinning then the laser was probably knock ajar and will need adjusted. There are good step by step instructions on several sites if you search for that. I had to do it to mine that would spin and then say disc read error. The whole thing does have to come apart but when you have it apart the adjustment is the easy part.
Oct 28, 2009 | Sony PlayStation 2 Slimline Console
EMERSON MS3110
it sounds dumb, but i actually wiggled it back and fort (the whole unit) and it started to spin the disks
Feb 11, 2008 | Emerson MS3103 Shelf System
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
