Question about NAD T770 Receiver
NAD T770 (T2 Monitor button)
My NAD continually defaults to the T2 Monitor while playing especially after start up,thus muting the sound,
  • 1 more comment
  • davebiomed Jul 02, 2008
    I have the same problem have tried shorting the tape - 2 inputs no change.
    has had this problem for most of it life it gets better after a warm up. To old to fix to good to through away ???? Dave Brisbane
  • rjelles Aug 10, 2008
    I see the same behaviour with my T770 - the T2 monitor switches on and off every few seconds at first, then gradually the cycles are longer as it warms. The NAD service centre appears to be aware of this, and said it is due to a heat sensitive switching component. I was hoping to find out if the T2 monitor function could just be disabled, but haven't had a response yet from NAD.
  • acimon Oct 06, 2008
    My T770 has the same problem... you guys mentioned that the NAD service center was already aware of the issue, but can't they fix it? I had that problem for a few years, it seems to get worse over time.
    I would really hate to have to throw away my receiver... but if I'm forced to, I sure won't get another NAD. It worked well for about 5 years, that's it...
  • 3 Answers
The best solution for this problem is to throw it away and never buy nad again. its junk.
Posted on Jul 22, 2009
How to remove the T2Monitor indicator light to have sound
Look for a button labeled 'tape monitor'. That is what the T2 monitor is. When you press that button, it will toggle on and off.
Jun 14, 2013 | Onkyo Audio Players & Recorders
I have 42'' PDP monitor. As of last night, there is no volume. Pic is fine.
Ilene,
sounds like a) your audio amplifier IC chip is fried, or b) cold solder joint to the speaker(s).
Any chance your pet stepped on the "Mute" button on the remote control?
Or perhaps there's a book on top of the remote which is continuously transmitting the "Mute" Infra-red code?
Any chance that someone has selected "external speakers" in an on-screen menu, thus disabling the internal speakers, and sending the sound signal to RCA jacks on the back of the set to which
nothing is attached? perhaps this setting may be called "Surround Sound?"
Dec 22, 2010 | Maxent Televison & Video
How do i turn off the sound
You can use the function button in your keyboard + Mute sound button in the top keyboard rows to mute and unmute the sounds.
(fn key + Mute symbol key)
I hope this is helpful to you.
Thanks
Apr 26, 2010 | Dell Inspiron 2200 Notebook
Hi, i have a nad c325 bee amp and i have a problem with hooking up speakers. I have just the tiniest amount of sound coming out so there's some signal there. I have tried different speakers so i know its...
Before you continue, turn the volume DOWN. If you can't hear it at mid-volume there's no sense in spinning the volume knob higher. You'll only endanger your ears and speakers if you suddenly resolve the switch or whatever is the problem.
Are all sources acting the same?
Check these things (from the manual):
Tape Monitor selected?
Muting?
Headphones inserted?
Jumpers missing between Pre-Out / Main In?
BTW: the manual is available at retrevo.com
Apr 06, 2010 | NAD C325BEE Amplifier
Error s10
Did it ever work properly? If not, let's get down to basics and set it up for the simplest configuration it can have: FM source in stereo with front left and right speakers, no Surround Mode, no DSP, no Tape Monitor, no Mute, Volume not turned all the way down. Does that work?
Do you have Surround Speakers defined in System Setup A? If not, only Dolby Surround or Off are valid Surround Modes.
Is T2 Monitor indicator lit? Press the Tape-2 Monitor.
Is there acceptable sound other than during Speaker testing? NO? Is MUTE On?
Apr 29, 2009 | Onkyo TX-DS838 Receiver
No sound
Check the speaker icon in the taskbar at the bottom, if there is an X then it is muted. Right click to unmute.
Also as it is a laptop there may be a mute button on the keys using the function button and a typical mute icon on a key or even a seperate button altogether.
Mar 18, 2009 | Microsoft Windows XP Home Edition
No sound
Is there an indication of protect mode on the front display? Have you checked to see if the tape monitor switch is on? Did you hear a click when you first turn on the receiver followed by a second click?
Dan
Apr 17, 2008 | Onkyo TX-SV727 Receiver
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
NAD T770 Receiver Logo
166 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
