Question about HP Computers & Internet
Notebook won't boot with new AC adapter. My son borrowed my HP 530 notebook and left the AC adapter in another city. About a month later, he ordered a new AD adapter, but the laptop won't boot. What could be causing the problem?
    President:
  • 2,571 Answers
If you used the wrong adapter with the wrong voltage/current you could have damaged the battery and the laptop
Posted on Jul 18, 2010
HP 530 won't see hard drive
Are you sure there is no usb / CD in the computer?
Try pressing F8 when the computer boots and select the HDD as the boot device.
If this works, you'll need to reset the boot order in the CMOS / BIOS.
Apr 11, 2013 | HP Business Notebook 530
HP Pavilon dv6910us Entertainment PC Defective ac adapter connection? ac port?
Sounds like your Internal DC Power Jack is broken. It has to be repaired or eventually it will completely break and you won't be able to boot after the battery drains. It calls for taking your laptop apart since it is on the motherboard or sits in a slot on the motherboard. Most times it is soldered on the motherboard. You have to unsolder the old and solder a new on it it's place.
Mar 27, 2012 | HP Pavilion dv7-1132nr Notebook PC
HP 530 wont boot Windows 7 DVD
the 530 came with XP or vista,. never W7,
the HP support only supports those 2 OS, period.
F9 key boots to anything and DVD , the DVD-r is bad or the DVD drive is bad, why not boot to USB stick? if that works then the DVD is bad. (burned wrong or drive itself bad.see?
Tell us what media you are using? (WHO's from Where?)
tell us what you want to do:
1: run XP,Vista or W7, what?
if running XP or VISTA before, the F10 ( changed to F11 later)
F10 loads the OS fresh, off the working HDD, partition called the
HP recovery partition, this is how to get the 530 back as day one.
if you use a Microsoft media, it will be missing key HP drivers and will be missing all HP software. a fact.
again, where did you get your media.?
my guess, is you MADE it from DVD-R , right.?
using what ISO, from Microsoft or from HP?
using what method (I use Imgburn? free, and is best) ask how.
this PC is carbon dated at 2008, (1 more year of support left, hint)
be wise to download all the below so when HP deletes all this soon.
you have it.
or buy the HP media kit. and never need to ask for it again.
hp sells it. buy it. now. while still sold.
btw2, many DVD drives are bad, or need service or cleaning
and fail to read disks properly,for sure huge OS loads !
and when DVD does work , it takes 1/2 day to load windows
we use USB sticks today, that work all the time and run fast.
burn stick instead of the disk. and win.
we use RUFUS to burn the ISO to STICK. (ask, millions do)
then, F9 boot to the USB stuck called Udisk.
it boots fast and works. (at least installs fully)
if using MS, w7.iso, there is no guarantee it will work with all
drivers working on a 530.
you tell us...
the Microsoft w7 load will takes a license key ,
the bottom sticker on the 530 has COA sticker , for OEM XP or VISTA, (unstated by you)
only OEM Disks installs work with that sticker,
if you buy W7 , its called retail and can work if luckly , sans all HP software with it.
here is the official page. this works, every time.
but MS does not support it now, updates are dead. and more. at MS now. they ended it 3 years ago.. and Vista last month.
(yes, 1 patch was released for the In the news ciberattack)
https://support.hp.com/us-en/drivers/selfservice/hp-530-notebook-pc/3375953/model/3375995
May 16, 2017 | HP 530 Notebook
I have a HP Pavilion dv8225nr notebook pc and when I plug the ac adapter into the notebook the battery light keeps blinking and it wont hold a charge. When I keep it plugged in and I turn it on it wont...
It is most likely a bad AC adapter. One way to test it is to remove your battery (I put the steps to do this below) and just plug the laptop in with the battery removed. If it does not power up then your AC adapter is bad. You can buy new batteries online or at your local electronics store. I would advise against buying them from a store though because they are usually much more expensive. I did a quick google search and found some on amazon for a pretty good price.
http://www.amazon.com/HP-Pavilion-DV8225NR-Battery-Replacement/dp/B003KVZIQ2
Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
b. Slide and hold the battery release latch to the left.
(The front edge of the battery disengages from
the computer.)
c. Lift the front edge of the battery up and swing it back.
d. Remove the battery.
Jun 17, 2011 | HP Pavilion DV8225NR Notebook
I have tried removing battery and reinstalling. i have reset with button and have used new ac adapter. I get power to laptop but all it will do is the power light blinks like in standby mode. it will not...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
Please get back with the results.
Mar 19, 2010 | HP Compaq Presario 2135US Notebook
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
HP 530 Laptop, NO Power
Um apart from growling at the dog lol you will probably need a new keyboard section.
Apr 25, 2009 | HP 530 Notebook PC
Notebook will not boot up
First take out your battery. Now plug in the AC adapter and turn on the unit. If it comes on, then let the battery "Rest" for a couple of hours. If it does not come on then your unit needs to see a reputable repair person.
Apr 08, 2009 | Acer Aspire 3680 Laptop
Wont power-up with AC adapters, with or without Battery!
the notebook cannot be charged without the charger and further more if it is not working properly ,try get a new one and it will work.i also recommend that you show it to a technician .
Dec 24, 2008 | MSI MS-1022 Notebook
Power/battery problem
hi, try removing the batt press and hold the power down for 1 minute, dont replace battery yet, plug in charger, boot up then shut down. replace battery and boot.
if this fails you could also try changing your power settings in control panel. change to minimal power managment.
remove the adapter while laptop is on and allow to completly drain(untill it switches off)
then try reboot.
Dec 19, 2008 | HP 530 Notebook PC
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
