Question about Microwave Ovens
I have side by side frigidaire gallary that leaks on the freezer side cleaned out freezer and found that the drain hole is froozen ,thawed it but keeps happening
  • 821 Answers
Hello,To correct the problem, you must locate the drain and inspect it for blockage. Often, you'll find it frozen, but it's usually always solid debris blocking the flow of the water that's CAUSING it to freeze: and that must be removed from the drain or it WILL happen again.
Where is the Drain?
After unplugging the fridge from the AC power, go ahead and pull the unit out where you can access the back. This is also a GREAT opportunity to clean dust off of the condenser coils and compressor, which will GREATLY lower your energy costs! (Use a Vacuum with brush attachment)
Depending on the model of refrigerator in question, the drain port can be located in several places. The most likely location is just under the freezer, which is actually the top of the fresh food compartment: The tube usually comes out there, and down the outside of the refrigerator; (On Back) However, it can also be under the coils behind the false back and/or side walls. At any rate, when looking for it, keep in mind that its' sole function is to drain water away from the evaporator coils when the unit is defrosting itself; Therefore, it's almost ALWAYS just under the freezer at the end of a "channel" that directs all of the water into it
Cleaning the Drain... Depends on what's causing the clog.
If it's iced up, the quickest way to thaw it is with a hairdryer. It takes just a minute with the hairdryer set on max.
Before you get happy and close everything up though, ALWAYS check the tube for debris.
About 95% of the time, I've found something in a frozen drain line. Remember: It wouldn't have been frozen in the first place if the water had been able to drain off!
After checking the pan under the freezer for debris in the pan and exit hole, you'll need to check the tube itself. The best test is just to blow through it like you would a straw. If it's clogged, you'll feel some resistance.
wish you good luck,
take care.
Posted on Jul 18, 2010
  • alrodriguez1 Jul 18, 2010
    hi, I did defrost the drain by putting table salt on the drain and that worked but one week later it happened again , pleez help
Leaking water from freezer door
The drain hole can be cleaned by inserting a long piece of straw inside and playing it in and out. Flush it with water to make sure the blockage is gone. This usually algae or mold.
Jan 11, 2014 | Microwave Ovens
Sunbeam chest freezer SBCF5WBX appears to operate but suddenly stopped being cold. It defrosted and thawed contents. Power is on and all electric lines and connections are in good condition. Freezer is...
Where you say that it appears to operator, do you mean that the compressor is working? If so, then your condenser grills might be dirty and causing the unit not to cool effectively. Is the sides or back of the unit getting hot? If so that could be the cause - a cleaning of the condenser coils.
But if your compressor is not kicking on or is very hot to the touch, then it might not be operating correctly. If it is not activating then it could be the contactor-relay or start capacitor.
Sep 10, 2011 | Microwave Ovens
Have a kitchen aid side by side refrig that stopped working tonight. Model KSRB25FH with ice maker. Noticed ice was wet earlier today and tonight food has thawed in freezer section and refrig was not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Microwave Ovens
How to defrost freezer model #4931 montgomery ward .There is a drain at the bottom , but is there a drain pan to empty? Do I take the back panel off?
There is a drain plug at the bottom center under the basket. Remove this. Snap out the base cover and you will find a hose behind it. Place the hose in a pan to collect the water. Turn off the freezer and let it thaw. Watch the pan that it does not overflow. I sometimes use hot water to help the melting process along.
Aug 06, 2011 | Microwave Ovens
I have a side by side fridge and the freezer side just keeps on running like all. The motor is really hot and the floor under the fridge is too.
Sounds like the compressor starter is locked up and needs to be replaced. Or the thermostat is either stuck or the contacts have melted together and it will continue to run till replaced. You can unplug it for a while to see if cooling down will help but if not then you will have to use the plug as the on off switch till you get it replaced. Is the fridge cold? is there ice built up all over the coils, this also might cause the issue if the coils are froozen and the unit is running but not cooling. The freezer is what cools the fridge so if the fridge is not cool then there may be a problem with the coils.
Here are some trouble shooting tips.
www.acmehowto.com/howto/.../refrigerator/diagrefrigerator.php - CachedSimilar-
Jul 10, 2011 | Microwave Ovens
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
Frost water in the floor of the freezer
The defrost drain hose in the back of the freezer is plugged. Clean out the freezer and let it thaw, then search for the hose inlet.
Mar 08, 2011 | Microwave Ovens
Water is leaking on then freezing on the floor of my upright frigidaire freezer. At first I just thought it was a fluke and cleaned it out, but he next day their was frozen water again. I also am finding...
Your freezer goes to a defrosting cycle and actualy melts away some ice formation inside the freezer, normaly this melted ice (water) drains trough a tube in the back of the frig... the drain is probably clogged and the water spils out... to unclogg it you need to find the uper end of the drain (where the water drips in) usualy way in the back of the frigidaire, than try pushing a long wire in downwards to unclogg the drain, also check underneath or in the back of the frig. ther should be a back to hold the water for the time it evaporates, see if it is not full of water or dirt (dust) i even foud some pet toys in there once ha! ha!
Hope this helped!
Mar 02, 2011 | Microwave Ovens
Water is leaking down through what i am calling the vent in the top of the fridge inside and it is building up over a few weeks and then it runs out on the floor.
I have experienced this very same problem before. There is a small condensate drain hole in the rear of the freezer compartment on some model refrigerators. If it ices over, the condensate has no where to go but down through the louvers and into the refrigerator compartment. It usually drips from the center overhead area down on to the shelves and accumulates in the bottom until it runs out the bottom of the door.. One way to tell is to check the back of the refrigerator to see if there is a visible drain line (larger in diameter than the ice make water line) that runs from the freezer compartment down to the compressor area. You may want remove everything and defrost the freezer and see if the problem goes away.
If you have questions/concerns, please post back with your MODEL NUMBER and let me know. I hope this helps you.
NOTE: Even if this is a frostless refrigerator, I have experienced the problem where ice can build up and plug the drain. You may have to remove the bottom tray in the freezer to access it.
Aug 27, 2010 | Microwave Ovens
AMANA UPRIGHT FREEZER LEAKS WATER FROM THE DOOR
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 14, 2010 | KitchenAid Architect II KBHS109SSS...
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
