Question about Danby DBC2760BLS (5 cu ft) Wine Cooler
New out of the box Danby Silhouette beverage not cooling
New out of the box Danby Silhouette beverage center - has been plugged in for about an hour but is not cooling - compressor is on and air coming out front vent....what is wrong?
hotuna
  • 288 Answers
SOURCE: Brand new out of box and will not cool - after 12 hours - compressor is very hot ?
First question is, are there any fans that are built in that are not running? next is there may be no freon in the unit. Ive seen new stuff from the factory have no freon inside. feel the suction line (the bigger one) from the compressor. It should be cool. The discharge line (smal one) should be hot.
Posted on Dec 24, 2007
  • 172 Answers
SOURCE: Danby Silhouette Wine cooler won't
Hi sooner84,
I really like the Danby wine coolers, they are usually nice products. As far as your problem, I would first try to find out where the main problem area is. To do that first make sure that your compressor is running. If the compressor is running and it is not cooling then you may have a freon charge issue. Thats not to say that you can just put some more freon in and it is fixed, You would have a leak in your sealed system and you would most likely still have warranty coverage for that. Most Danby products carry a 5 year sealed system warranty. That would include your compressor.
If the compressor is not running then you would know that you have a compressor issue. Either the relay overload on the compressor would need to be replaced or the compressor itself was bad. You can buy relay kits for about $30.00 and intall them easily with very little experiance.
Next if the compressor is doing its thing and trying to cool you could have a fan not blowing air properly. either a condenser or evaporator fan may have stopped. If you find one not working then chances are you just need a fan. If the fans are blowing and the compressor is working then you would just have a defrost problem. In that case you would just need to defrost then check for bad parts, either a defrost heater, defrost thermostat or a defrost timer. Most of the Danby products have a defrost control board, that board willl contorl the defrost, the temperature, and the fans. If the board was cheap I would say just put one on and see if it fixed the problem, but they are around $145.00.
The most important thing for you would be to make sure you are not going to do something that would void your warranty. Free service is always the best. Good luck to you and send some wine my way, I make lots of different types. from grapes, strawberrys, muskedyne, etc.... mca0824@aol.com
Posted on May 02, 2008
  • 50 Answers
SOURCE: Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
Posted on May 18, 2008
  • 154 Answers
SOURCE: Error code E 04 was
most error codes are to do with the main board or a switch board and ussually need to be replaced. If you have the manual for it they normally have the error codes and there meaning in them. If not in the manual you should ring your nearest repairer and give them the make model and error cdes and they can ussually tell you what it is from.
Posted on Jul 22, 2008
koolbreezes
  • 540 Answers
SOURCE: danby silhouette dpac120060, there is
Was this gradally or all of a sudden, cause the thermostat switch could be bad or it vibrated and spranged a leak!
Posted on Sep 04, 2008
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
Purchased in 2010. Temperature doesn't fall below 55F. Fan works. Sounds like compressor is working. Haven't physically inspected compressor. Used to cool to 39F.
May be both. Is the evaporator blocked or have ice built up on it? If so there could be two reasons for that. Low on freon or not enough airflow inside the cabinet.
Aug 08, 2015 | Danby Silhouette Series DBC514BLS 5.3 cu...
How do I turn off the danby silhouette
There may be an on-off switch or if not, pull the plug.
Nov 29, 2014 | Danby DBC514BLS Silhouette Beverage Centre
Danby Kegerator runs but does not Cool
sounds like maybe no coolant in system if compressor is working. you know like in your car a/c unit, sometimes refrigerant needs to be added. just a guess, I'm not an expert.
Nov 08, 2012 | Danby DKC645BLS Compact Beverage Cooler
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
Kegerator is flashing "EE" and
I bought a new kegerator and the same thing happened right out of the box.
The display was not pluged in.take Take screws off top and check to see if it pluged in.
Nov 18, 2010 | Danby DKC645BLS Compact Beverage Cooler
My danby beverage centre does not cool anymore 3 years old. compressor is hot. fan sounds and appears to work well all coils are clean.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 ,.,
Oct 06, 2010 | Danby DBC514BLS Silhouette Beverage Centre
Danby freezes all beverages
check position of thermistat bulb it should be on the plate
Jul 26, 2009 | Danby DAR259BL 2.6CF Silhouette Compact...
Danby DBC2760BLS (5 cu ft) Wine Cooler Logo
215 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
