Question about Friedrich D50 Dehumidifier
Settings what should i set the dehumidifier in a finished basement. I just purchased the D50D. Thank you, MJS
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
Typical human comfort leve is in the range of 40 - 60% RH. I'ld go with 60 so I didn't have to empty the bucket so often and less run time means lower electric costs.
Posted on Jul 19, 2010
We purchased a KSTAD50B Keystone dehumidifier for our basement. What are the auto start and stop settings suppose to do and do I need to set them for routine use.
page 5 of your instructions that came with unit.
Auto-Restart If the unit breaks off unexpectedly due to the power cut,
it will restart with the previous function setting automatically when the power resumes.
https://images.homedepot-static.com/catalog/pdfimages/b6/b6ada1d8-fe78-44d2-80de-b27496221241.pdf
Aug 04, 2018 | Dehumidifiers
How to adjust the humidity level
Hello Friend, that's a great question!
In order to better assist you I would need your model number please. The serial tag, which lists your model number, is typically located behind the bucket on your dehumidifier. Also, what is the size of your room/basement? Where is the dehumidifier located? What setting is your dehumidifier set on? With this material I can provide you the correct information. Thank you! - Z
Sep 03, 2014 | Dehumidifiers
What should I set my dehumidifier at for my basement
50%
Please rate 4 stars if this is helpful. Thanks and good luck!
Apr 22, 2014 | Kenmore 54701 Dehumidifier
I've misplaced the owner's manual on a DEN 500 P. What is a good basement setting for Summer in Central Ohio? Is a manual available on line?
I bought a cheap digital humidistat at Walmart to keep an eye on the humidity in my basement. I hung it on the wall not too near my dehumidifier. I have found that the settings on the dehumidifier are misleading, but I found a setting that keeps my humidity between 40% and 55% (at around 70 degrees), as measured by the humidistat.
Jun 04, 2012 | DeLonghi DE500P Dehumidifier
Hello there, I have a split entry home with a finished basement. I was wondering: on nice warm days, with a wind blowing through the upstairs, if I can leave my windows open upstairs while the...
Connie, it will only work if all of the interior doors to the basement are closed during this time. Even putting an old towel at the bottom of the door(s) leading to the basement will stop the air flow.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Dehumidifiers
I just bought a friedrick 1883 50 pint dehumidifier but it came with no manuel. it's working great except its not collecting water in the water tray. what am i doing wrong?
Go here for a manual along with other resources.
http://www.friedrich.com/support/brochures-and-manuals/residential-dehumidifiers
I suspect that it isn't collecting water either because there is not enough moisture in the air to remove any water, or the humidity setting is to high.
Thumbs Up if helpful, Feedback is Appreciated!!!
Jun 17, 2011 | Dehumidifiers
My dehumidifier does not drop any water into the drawer. I cleaned the filter and made sure the settings are correct. My basement has 67% humidity, according to the gauge. The unit is less then a...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 29, 2011 | Haier 45-Pint Dehumidifier
What should I set it at
If there is actual water in the basement, any setting will probably cause the unit to run. I would suggest setting it around 60%, and turn it up as you feel necessary. Hope this helps
Apr 01, 2010 | DeLonghi DE500P Dehumidifier
I recently purchase a house in Northern NJ and have quite a bit of Humidity in the basement. The central AC is connected to the basement but i barely run the AC because it has not gotten that hot. I am...
dehumidifier for sure!, usually a small 200$ unit will do the job. you can even hook a hose to one to drain it so you dont have to empty the bucket all the time. as for your house, when its raining hard outside, walk around you house and see if there is any areas where water is going in beside a wall. also long eavestrough pipes away from the house helps alot
Jul 30, 2009 | Santa Fe (4025699) Dehumidifier
Dehumidifier automatic on and off function not working
Unless you live in a dry environment or place the unit in a hermetically sealed room, it probably will not turn off. As the air dries within the room, more moisture comes in with the air. As long as the air outside of the room is more humid than the room this will be true.
Mar 10, 2017 | Whirlpool Gold AD70USS 70 Pint Per Day...
Friedrich D50 Dehumidifier Logo
93 people viewed this question
Top Friedrich Dehumidifiers Experts
bobalix
FixIt_Right
Tom Chichester
Are you a Friedrich Dehumidifier Expert? Answer questions, earn points and help others
