Question about Kodak Easyshare M753 Digital Camera
Camara lens on my C182 will not detract and no way to turn on even with new battery's! . . . . . GK
  • 4,889 Answers
I am afraid you have the notorious Lens stuck problem. It is usually caused by mechanical failure of the lens motor or grit/dust/sad in the lens gears. You can force the camera to try retracing by
1)Remove the battery and hold for two min
2)Put it back press and hold the power button for 10 seconds.
3)When the lens motor attempts to retrace the lens, gently assist it by pushing the lens in, then repeat steps 1 and 2 to reset the error code.
If it does not work then I am afraid the camera has to be disassembled to fix this problem. Time for a trip to the service center?
Posted on Jul 18, 2010
I turn on my camara and then the lens makes a noise and it turns of right away,i charge the battery (fully) and it still turns off
maybe because you have a lens error trouble, Lens errors (system errors) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:wish you luck thanks
Feb 21, 2012 | Sanyo VPC-X1250 Digital Camera
Kodal easyshare c182 camera lens is extended and won't retract, with error message "Lens error 180051" can u help me
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 17, 2011 | Kodak Easyshare C182 12MP Digital Camera
Still getting a lense error 211 on my Kodak easy share c182 camera.....haven't even barley used it eather!!
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | Kodak Easyshare C182 12MP Digital Camera
Kodak easy share c182"lens error 211" will not
I went with other advice, gentle drop on carpet sorted it :-)
Jun 09, 2010 | Kodak Easyshare C182 12MP Digital Camera
Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
Mar 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
My camara wont turn on
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Aug 27, 2009 | Kodak EasyShare M863 Digital Camera
Battery warming up the camara
Was your camera working before you put the new battery? if yes, then its possible some dirt or grit has got stuck between the lens and the body and therefore you motor might be warming up.
Since you 've bought a new battery, I dont think It may not be the battery, the way you are explaining. It could be the lens motor itself, since its warming up.
Try to do the following: ( I 've got this checklist from the forum itself)
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
6: Repeatedly tap the padded/rubber usb cover with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand.
Try the above and let me if its any help.
Best of luck
Mar 07, 2009 | Casio Exilim EX-Z40 Digital Camera
Vivicam 8400
I have a ViviCam 8400 and have the same problem UNLESS I buy Duracell Power Pix or Energizer Titanium batteries. These cost more than the regular grade AA batteries, but when I used brand new regular batteries, the camera would turn on for 2 seconds then turn right off. Titanium or Power Pix batteries make the camera work fine. And, because they are made for digital media, they do allow you to use the camera for longer periods of time.
Jun 09, 2008 | Vivitar ViviCam 8400 Digital Camera
CAMARA turns off when i press to take a photo
I have the same camera... and it was doing the same thing AFTER i changed my old batteries, because they were getting low. It was only after i put in the NEW batteries that i had this problem... I tried putting the old batteries back in and sure enough it worked again, so it probably all just depends on the brand of the battery you use.
Oct 09, 2007 | Fuji FinePix A500 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
