Question about Panasonic PT-53WX54 53" Rear Projection HDTV
It blinks 5 times. i just had the convergene replaced or repaired
  • Panasonic Master
  • 3,459 Answers
Possibly bad soldering or a bad chip
Posted on Aug 14, 2010
No picture or sound, red light blinks 5 times, already replace tcon and power board still blinks 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 17, 2015 | Samsung UN40F6300AFXZA - UN40F6300AF 40...
Retiming problem
It sounds that the convergence IC is faulty. Replace it, and check. If you wish to get more details about convergence settings to projection TVs, check the link given below. Pull up older posts there.http://electronicshelponline.blogspot.com/
May 31, 2013 | Televison & Video
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
Has a convergence problems is it neccesary to replace the 220 resistors, and the 5% Not sure of value.
you must go in yhe meny and set convergens point to point...or use the auto function.....try to reset to factory first.....NOT REPLASE 220 RESISTOR..
Aug 18, 2010 | Toshiba 43H72 43" Rear Projection...
Power will not stay on
u have a problem with the convergen ic , and 2 pico fuse on power supply , this repair normally cost about $300
Apr 13, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The color is goning out. the convergen is not working.
Go to this website.Tv Repair World.com,buy a whole a convergence for replacement.
Jan 04, 2010 | Zenith R40W46 40" Rear Projection...
Red stand by light blinking
5 blinks = lamp driver (ballast) failure.
1-468-798-14 for the 610 model
replacement is done from the back of the set, should be straight forward, keep the red ballast wires apart for best results
if a tech replaced the red tube, you have an older tv where 5 blinks is the AKB error meaning your CRTs are getting old.
Nov 17, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Daynamic convergen
You will need to put unit in service test mode to adjust conv.. Also you will need a convergence (cross-hatch, dot and line)pattern generator for proper alignment
Jul 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
