Question about Husqvarna 24HP 54" Yard Tractor ()
My 54" rider cuts into my slighty hilly and rough ground. Even on fairly level ground if there is a raised bump the opposite side will dig into the ground and I have a lot of bare ground slices throughout my large lawn. how can I adjust that deck so it doesn't cut into the ground as much. dave Cooper
    President:
  • 2,702 Answers
You need to life the deck higher, your using it as a rotorvator not a good thing to do? try rolling the lawn flat as well,,
Posted on Aug 01, 2010
Husky yth1542xp. I've changed the blades, leveled
When levelling the deck, rotate the blades so that the right blade has one of its cutting edges at or near the right side center of the deck. Do the opposite with the left. Measure to the blades from the level ground, not to the deck. Try leveling that way.
Gary
Jul 03, 2011 | Husqvarna Garden
Adjusting John deere ''Sabre'' model deck
Move machine to flat/level surface,with deck raised put a 2x4 between rear of deck and ground.Make sure that the 2x4 goes all the way under deck from one side too the other.Once that is done lower deck all the way and make sure lift lever is all the way forward.Then on the rear top side of deck loosen bolt that holds arm to deck bracket,pull bracket as far down as you can then retighten bolt.This is also the point where you can level deck side to side.
May 03, 2010 | John Deere Tractor 1020, 1520, 1530,...
While on hilly road with lots of bumps and potholes, brakes fail
check brake fluid level if LOW good indication brakes are due.
Apr 21, 2010 | 2007 Toyota RAV4
Husqvarna 54 inch rider, fairly new, bought used. Deck will not fully lower or raise even after levelling per manual. Are 54 in decks more susceptible to this type issue?
the Rake adjustment is critical on this mower make sure the front to back is within 1/4 inch of each other with front being the lower this adjustment is on the front if its a single rod the bracket that attaches it to steering axle is probably sprung back this happens from running the mower into something with the deck.
Dec 02, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Deck digs into ground
Try raising the mower's wheels one notch. That should lift the deck high enough to clear the ground and still cut to an acceptable height. Try it, if it doesn't work let me know here.
Oct 18, 2009 | Toro Lawn Mower With Toro Power Tools
How do you adjust the cutting deck?
Pete, go back to partstree and look at the diagram for lift arms. Item #27 is your lift cables. You will notice there are several little ferrules or balls on the cables, you unhook the cable and slide these up or down as needed to adjust your deck. If you need the deck higher, you would position more of the balls under the lift arm on each side. If you can't get the desired height then your cables are stretched and need to be replaced
Oct 09, 2009 | Garden
How to adjust mower deck height
There should be two threaded rods with a nut on them that goes from the frame to the deck. Check the height of each blade and which ever side is out of balance you can disconnect that sides rod (usually held onto the mount with a clip or cotter pin) and turn the rod to either raise or lower your deck until it is level.
The above was for leveling your deck.
If you just need to raise or lower the deck depends on if you have a lever on the right side with a push button on top just depress the push button and push forward to lower or pull back to raise.
It might have a round knob that you turn to raise or lower.
Good luck
Sep 03, 2009 | Garden
Rider cutting uneven
check and see if you have a bent blade. If bent replace. If the blades are not bent then you need to check the levelness of the deck. You can measure the distance from the blade to the ground on all the blades. Make sure you are on level ground. If one set of blades is higher or lower you will need to level the deck. Refer to you owners manual. If no owners manual there is probably some hangers that are threaded and has a nut on it. Loosen one to lower and tighten to raise. Only do one side.
good luck
roundo4
Aug 30, 2009 | Toro Lawn Mower With Toro Power Tools
Uneven cut
I suggest you park the tractor on a level hard surface. Measure from the bottom of the deck to the ground on both sides of the deck to see if it is mounted level. The next thing to check for is a bent blade. Good luck.
Jul 06, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
RIGHT SIDE BLADES CUTS LEVEL, LEFT SIDE DIGS INTO THE GROUND
the right side cuts level but left side doesn't well the answer i have would be that someone stepped on the deck which will cause the adjustment arms to bend & deck will not be level or the only other thing it could be is the blades could be bent as well if i can further help e-mail me @ wadembly@aol.com thanks ,wade
Jun 08, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Husqvarna 24HP 54" Yard Tractor () Logo
134 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
