Question about Polaroid 15'' HDTV Monitor FLM-1511
Polaroid FLM-1511 Monitor
How do I connect my Polaroid FLM-1511 monitor to my laptop. I attached a VGA cable to both and pressed source, but nothing happens. My laptop is Microsoft 7. I do not have the remote control to the television.
    President:
  • 2,571 Answers
Right click on your desktop / display properties (mine is nvidia display properties)
There should be settings there to set up multiple displays.
You may need to find display properties from control panel
Posted on Jul 18, 2010
SOURCE:
When I play videos the sound from the monitor is fine. However, the auxillary jack in the back of the monitor makes static when I pulg in the outside speakers, but their is no sound from the video. I...
The auxiliary connector could be an input as your Polaroid monitor instructions would indicate. There may be no provision for external speaker connection.
Nov 26, 2013 | Polaroid 15'' HDTV Monitor FLM-1511
How can i get the computer sounds to play thru the built-in speakers of polaroid flm-1507
You need a cable with mini-phone plug at both ends (Radio Shack), one end is plugged into the monitor audio input jack (Green), the other end will be plugged into the PC audio line out jack (Green).
Dec 16, 2010 | Polaroid 15'' HDTV Monitor FLM-1511
No pic just sound
Recommend you verify where the video plug is inserted in rear of TV, there are video in and video out. If you have audio going in from cable/sat box, but video going to video out (instead of in), this could create the situation you describe.
Also make sure you are on the correct 'source' setting if you are using Video, etc.
Feb 10, 2010 | Polaroid 15'' HDTV Monitor FLM-1511
Screen says no input signal
what kind of cable do you use? dvi or hdmi? try reseating the cable and video card.
Dec 03, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
Connect from wall cable to tv.
you are trying to use a monitor as a tv, you will need a tuner to get a pic, use a cable box or digital to analog tuner to get something
Nov 17, 2009 | Polaroid FLM-3701 Television
I have my polaroid hooked up with an hdmi cable
Thats because your TV is not high definition and cannot process the high def signal. serial hook up does not give a highh def signal.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 09, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
Hooking up a ps2 to my monitor.
ok " your tv monitor has a remote, look on the remote and push the input button .
also make sure video cable for ps2 is pluged in to the tv video
input plug, female RCA plug should be yellow
Jan 21, 2008 | Polaroid 15'' HDTV Monitor FLM-1511
Looking for driver for 15" LCD Television - Model: FLM-1511
Hi Billy. You don't normally need drivers for a monitor of this size. The most common cause of of this problem is that your old monitor was set to a lower resolution than this monitor is designed to support. LCD monitories have a 'native' resolution meaning that the screen itself is made up of 1280 x 768 liquid crystal cells. You need to change the screen resolution to 1280 x 768; assuming you are using Windows XP click with the right mouse button an an empty part of the desktop and select Properties (or click Start, then click Control Panel then click Display), on the Settings tab, under Screen resolution, drag the slider bar until it says 1280x768 and then click Apply. Post back if you still have the same problem after this.
Aug 09, 2007 | Polaroid 15'' HDTV Monitor FLM-1511
Polaroid 15'' HDTV Monitor FLM-1511 Logo
279 people viewed this question
Top Polaroid Computers & Internet Experts
micky dee
Tom Chichester
Steve P
Steve P
Are you a Polaroid Computer and Internet Expert? Answer questions, earn points and help others
