Question about Kenmore Sewing Machines
I have a kenmore 385.1884180 sewing machine. The other day I ran a couple of seams to see if the machine still worked as I have not used it in a few years. And it stitched just fine. Today when I go to use the machine I changed the thread and the bobbin and now it will not stitch at all. The needle goes up and down but does not pick up the bobbin thread. I have read and reread my manual and have rethreaded the machine several times but just not working. Please advise.
    Genius:
  • 1,788 Answers
Make sure that you are doing the bobbin right, by that I mean, make sure that the thread is in the tension spring and you put your finger on the bobbin and pull the thread up, now bring down your needle to hook it. Look at your manual. If, you don't have your manual, go managemylife.com and download for free
Posted on Jul 26, 2010
Can a dressmaker sewing machine, ca. 1975, sew a consistent 1/4" seam? My new Viking Saphire and old Kenmore do an awful job so I'm trying to find a better machine for quilt making.
professional machines are only better at sewing thicker fabrics-faster theyowever have difficulties doing fine work (there not made for that) I like the old Viking machines , and you cant discount the old sears machines as well , in fact unless there is an obvious flaw with them (bent parts), I cant see why they cant sew straight stitches , try using one of those stick on reference line tapes to help the operator guide the fabric straighter into the machine
Oct 05, 2016 | Kenmore Sewing Machines
1249380 kenmore sewing machine
Depends on what stitch you intend to use. I do a lot of mending with a three step zigzag set to maximum width and minimum length -- see: http://www.picturetrail.com/sfx/album/view/24395076 A wide, short zigzag stitch is another popular choice, as is a straight stitch worked back and forth over the area: http://www.running-w-scissors.com/2014/01/tutorial-patch-mend.html
If you're just mending a seam that's come unstitched, a straight stitch or zigzag stitch similar to what's already in the seam is what you're looking for.
Feb 05, 2014 | Kenmore Sewing Machines
My CS6000i is freezing on sewing over seams and creating a terrible loud sound refusing to sew. it does not give an error message and once stopped it will be like it never happened, however I have to...
At Joann Fabrics you can buy a notion called a Jean a ma jig, it is something that you put under the rear of the presser foot so that the presser foot stays level and will go over the seam easily. Make sure if you use heavier fabric or are sewing on denim use a #14 or #16 needle so that it won't break. Good luck
Jan 28, 2011 | Brother CS6000i Computerized Sewing...
Bottom thread bunching up
First try stripping the bobbin or wind a fresh one with new thread double check tension settings and fit in the bobbin case
Dec 15, 2009 | Sewing Machines
Trying to find out what kind of machine I have purchased at sale
Serging is sewing but it only sews seams by "overlocking" the edges. This machine will not make buttonholes, darn or other sewing. Serging is great for knits and finishing seams. You got a great deal! Sell it if you don't think this is what you want. Many sewers have a traditional sewing machine and a serger. I have two of each.. plus an embroidery machine.. but then I am an addict.
Nov 04, 2009 | Sewing Machines
I have a question on my Kenmore sewing machine style 385.17626 When I start sewing, after a couple of stitches it starts to bunch up and not feed through. It's a tangled mess of thread and fabric. I'm...
Try using a double strip of tissue paper 1 1/2 x5/8 inch placing it about 3/4 inch under edge of fabric and middle of seam allowance. Start stitching on the tissue paper and continue onto the fabric to the end of seam. After that remove the tissue. You can also hold both threads and slightly pull them when you first begin the seam to help them reach the back feed dogs.
Oct 22, 2009 | Sewing Machines
Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Oct 06, 2009 | Kenmore 16622 Mechanical Sewing Machine
When I try to sew my machine jams a little every few seconds and is not sewing on top. When I try to remove the fabric it is stuck and there is a mess of thread underneath. I have cleaned and oiled my...
Although you already re-theaded and cleaned your machine, re-check this:
- Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your bobbin case. Re-thread your machine, reinsert and rethread your bobbin.
If that doesn't work, try this:
- Change your bobbin.There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
- Raise your feed dogs if your machine has this feature.
Note:
when you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
Sep 24, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Can these needles be used with my sewing machine?
Don't know if this is helpful...but I have a very old Kenmore and 2 Brothers. I used the same needles with all 3 machines. No problems.
Apr 13, 2009 | Sewing Machines
Sewing MAchine Problem
redo the bobbin, maybe its backwards.
Jun 23, 2008 | Kenmore Sewing Machines
Sewing Machines Logo
246 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
