Question about Goldstar Heating & Cooling
Hi. i have a gold star R1200. Its not working proplerly. For example when I turn the air conditioner on it blows out warm air. it has been tooken care of, but its just not working properly. Can you gice me an explanation on what is happening to my a/c?
  • 360 Answers
Hi, it's a compressor problem. Compressors are not user serviceable. It's either you need to refill the compressor or that you need to get a new one.
Take care
Posted on Jul 18, 2010
  • artis_landon Jul 18, 2010
    So how do i refill the compressor? and where is it located?
  • Quadri Olatunbosun
    Quadri Olatunbosun Jul 18, 2010
    It's located with the unit, call in an a/c repairer to help your refill it.
Bought 4 small Gold Star units in 2009. One quit cooling altogether, one blows slightly cool while the longer another stays on the less it cools. One did not cool well when it was new. All filters are in...
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28700000&pkw_=basket&model_id=5520000&NewWindow=1
Download this illustration and then using a good multimeter start basic troubleshooting.
All residential window air conditioners have a cooling system made up of four primary components, a compressor, an evaporator fan, a control or switch, capacitor.When the thermostat is calling for a colder room temperature the compressor is energized. It is normally very quiet. The evaporator is always located on the front of the air conditioner. It also has silver fins. Be sure it is clean. Use a foaming type cleaner and rinse with plain water. Because the evaporator is absorbing heat, it is very cold to the touch. The temperature drop causes any humidity in the air to collect on the evaporator - sometimes called sweat. There is a fan inside the air conditioner that circulates the air for the evaporator and condenser coils. The circulating fan and compressor are running simultaneously. The fan motor has two fan blades attached to it on either end. The fan blade on the inside part of the unit continually draws room air over the evaporator coils, which are cold. The fan blade on the outside part of the unit continually draws fresh outside air over the condenser coils, which are warm. Because the evaporator coils are cold, they cause moisture in the room to collect on them, much like a cup of ice water on a warm, humid day. When the amount of moisture increases, it begins to drip down off of the coils into the bottom pan of the air conditioner.
If the compressor fails to start or the fan you may need to replace the capacitor.
You may need a hard start kit.
Thermostat control The thermostat on a window air conditioner works by sensing the air temperature entering the air conditioner. As the air entering the unit reaches the set temperature it will cause the compressor to turn off. The blower may continue to run depending on the selection chosen on the control panel. Digital thermostats work on a similar principle but display a more precise temperature.
Test for continuity with the multimeter between the two terminals . Warm you should read continuity (contacts closed). If not change it.
Selector switches The air conditioner selector switches allow the user to choose the fan speed. The compressor always runs at the same speed regardless of the settings. If low cool is chosen, for example, the fan runs at a slower speed but the compressor still offers the same cooling capacity. There are other switches to control louver operation and other features on some units.
Jul 23, 2011 | LG Goldstar GWHD5000 wall/window Air...
It has been blowing warm air. It will blow cold air for about 5 minutes and then warm air all over agian.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Goldstar R5050 Air Conditioner
I have a R5203 gold star air conditioner, and the room does not get cold any more, also do you have to replace any fluids, its sounds dry and crackling.
heatman101
Apr 17, 2011 | Goldstar R5203 Air Conditioner
Goodman air conditioner is sometimes blowing out warm air. We've had this unit for 2 and 1/2 years. When we first moved in we had a problem with it not blowing out warm air in the winter. We had someone...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 30, 2010 | Heating & Cooling
BLOWING WARM AIR
Amana portable model AP148DS blows air turns on but will not cool.
Jul 10, 2010 | Amana Portable Air Conditioner
I cant get it to just blow cold air
seems like the coolant has leaked out
Aug 21, 2009 | Sharp ENERGY STAR AF-S60FX...
Heating & Cooling Logo
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
