Hi, I have a Fujitsu MHT2060AT hard drive that I would like to convert to an external hard drive with a cable adapter to USB. The cable adapter that I have accomodates pins: the hard drive has gold plated tabs instead. plese tell me what cable adapter I should purchase to accomplish this. Thank you.
    President:
  • 2,571 Answers
If the drive has tabs, it is a sata drive, the cable has pins, it is a IDE (pata) cable.
You need to buy an enclosure or caddy that is for sata drives
Posted on Jul 18, 2010
What is the connection plug from Fujitsu mht2080ah to computer?
You can install the hard drive into an USB hard drive adapter case.
Then you can connect it to the USB port on your computer. The computer will see this as an external storage device, then you can copy the files off this hard disk to your computer.
By inserting the hard drive into an USB hard drive adapter you can deleted unwanted files off the hard drive and use it for backups and data transfer from one computer to another computer.
Mar 31, 2013 | Fujitsu MHT2080AH 80 GB Hard Drive
I Need to know about the converter of MHK2120AT . i want to use this hard disk as external .
Yes, thats possible, you will need an external usb enclosure such as the one here:
http://cgi.ebay.com/2-5-Laptop-USB-2-0-External-IDE-Hard-Drive-Enclosure-/180555059491?pt=PCC_Drives_Storage_Internal&hash=item2a09eb9123
When you get it, the drive will go in it and then you can plug it in via your USB port on your desktop/laptop.
Regards,
Brandon
Computer Bytes
Dec 10, 2010 | Fujitsu Mobile MHK2120AT 12 GB Hard Drive
What kind of enclosure and cable do I need to make my drive exter
This drive is an IDE/ATA hard drive.
To use this as an external hard drive, I suggest you purchase an USB hard drive adapter case (with an USB cable) and install the hard drive into this case.
When you plug this adapter into the USB port of a computer, the computer will see this as an external hard drive.
Mar 22, 2010 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
My fujitsu mobile mht2060at pl hard drive does not boot
If you are able to acess the hardware just touch the hard disk with your hand and see if you are able to feel the vibration of the disk running? If No then please check the power cable which enters the HDD. If its running it means power is fine. So remove he data cable and reconnect it again and check what happens. Let me know if you have doubts in finding the problem.
Thanks
Sweet rascal
Feb 22, 2010 | Fujitsu Mobile MHT2060AT 60 GB Hard Drive
My fujitsu laptop recently had a new hard drive installed in it ,but i want to transfer the data i have on the old hard drive that was removed from laptop to my new hard drive. I bought the all in one...
The Coolmax adapter is an USB hard drive adapter that can connect various types hard drives to your computer. This is used for testing and and transferring data to and from hard drives connected to the computer via the computer's USB port.
This Coolmax USB hard disk adapter can connect a 2.5-, 3.5- and 5.25-inch IDE or SATA hard disk to a PC. The black adapter box connects the hard disk, while the secondary power plug/adapter powers the drive. In the case of smaller notebook or SATA disks, the power cable is plugged directly into the adapter (as opposed to straight into the IDE hard disk).
The red USB cable, meanwhile, can be used to power hard disks directly from the host PC's bus via another USB port.
Connect the hard drive to the adapter as detailed above, power up your computer and plug the Coolmax USB cable into the conputer's USB port. The computer will detect and see this as an external drive, most likely as a E drive (the next drive letter that is available). Click on this drive and open to open the folder/s where your data is stored then select the folder/s and/or data and copy them, then open the hard drive on the computer and paste the folder/s and/or files onto the new hard drive.
Sep 29, 2009 | Fujitsu Siemens Computers & Internet
Hi when I turn on my fujitsu amilo pro v2055 it says operating software not found. Can anybody help
The operating system software is stored on the hard disk. The computer cannot detect the hard drive and therefore cannot load the operating system. It could be that it only needs reseating to get it operating again, if that does not work it could be a faulty disk drive or a faulty disk controller.
To test if the hard drive is OK, remove it and connect it to an USB hard drive adapter and plug this adapter and drive into a working computer's USB port. If this computer see this as an external hard drive and you can view the contents of this drive, then it is OK. If you cannot see this drive then it is faulty.
You need to replace the hard drive in your computer and install Windows again to get an operating computer again.
May 16, 2009 | Fujitsu AMILO PC Laptops
Firewire/USB
Hi beccarkt,
Although not sold at Best Buy™, there are available adapters/cables to make this transfer possible. I recommend using a search engine to find "firewire to usb." Hopefully this will give you the results you need.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 11, 2008 | LaCie (300740) 160 GB Hard Drive
External Drive won't power on
Actually the simpletech dosent need power adapters so u dont need to check for adapters and if you are connecting to usb2 port the power should be embaded so just connect the single usb cable not the both if using usb 1 then connect the both usb cable to usb port if u have already done this please try to change the usb cables wich is connecting the hdd and the pc something wrog in the cable for sure
thanks
Jun 01, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Computers & Internet Logo
435 people viewed this question
David Payne
David Payne
