I HAVE A BELKIN WIRELESS G ROUTER (F5D7230-4) WHICH WORKED WRLL WITH MY WINDOWS XP AND VIRGIN BROADBAND. MY NEW COMPUTER IS VISTA THE ROUTER WILL NOT WORK. IS MY ROUTER INCAPABLE OF USING VISTA?
    Problem Solver:
  • 21 Answers
Check to see if your wireless card/dongle is working,and installed correctly.
Check at the manufacturers wesite for Vista Compatability
Posted on Apr 21, 2008
Can I use Belkin 802.11g Wireless G Range Extender with virgin broadband?
This is a highly technical question. The technician that installs your fios can help you with an answer. If i'm not mistaken your new fios will come with a special router designed to change the data your recieving to acceptable format and communicate with your other devices. As I stated the tech who installs your fios can further instruct you as to the exact configuration. Hope this helps.
Sep 02, 2012 | Computers & Internet
I have a belkin f5d8636a.4 wireless router and need to connect it to a new computer running windows 7 using a belkin f5d8053uk usb stick. i need to know are both these items windows 7 compatable or do i...
The Router supports a variety of networking environments including Mac OS® 8.x, 9.x, X v10.x, Linux®, Windows® 98, Me, NT®, 2000, XP, and Vista®
usb stick OS Compatibility: Windows® 2000, Windows® XP 32 bit, Windows Vista® 32 bit
Nov 28, 2017 | Computers & Internet
I cannot connect this router to my wireless laptop i am with virgin broadband the desktop pc works with cable into back of pc but cannot see laptop on network
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that you have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 07, 2010 | Belkin (F5D8231-4) Wireless Router...
Doesn't work with windows vista
1. check if there are lights on the specific router port where you have connected the Vista (e.g. if it is on port 2, check if there are lights on #2 at the front panel of the router).
2. check the ip address by going to command prompt (click start-run-type cmd press enter. on the command prompt, type ipconfig/all)
3. ip address should be similar to what your Windows XP is getting. Subnet mask, gateway, and DNS servers should be identical.
Eg. If XP has a 192.168.1.100 IP, your Vista should have 192.168.1.x IP address where x is a variable number other than 100.
4. If your IP address, subnet mask, default gateway, and DNS seems aligned for both PCs, check your browser settings. Open IE, go to tools, internet options, network connection and make sure that never dial a connection is selected.
Jan 16, 2009 | Microsoft Broadband Networking MN-500...
Belkin g router and Virgin - account not accepted
can you get a phone number?
the router may be block by Virgin Media, so that way people can't steal internet from it (that is if you have it unsecured) you may have to set it up with virgin over the phone, or have a local broadband provider try to set it up
Jan 08, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I have purchased a belkinf5d8233uk4 and have trouble connecting to virgin broadband as cable from virgin into modem is screw in can you help
you still have to use the modem from virgin, mine is setup the same but with a different router, you have the virgin rounter connected to the wireless router then the belkin wireless rounter connectes to you pc instead of the virgin router, your gonna have to log onto the router and setup some security to make the connection safe from others using it.
Sep 08, 2008 | Belkin Computers & Internet
I have bought a belkin wireless g router. my pc is virgin broadband i need to connect an aspire lap top. where do i plug in to make the router work
If you have your pc connected directly to your Virgin Broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Thanks
Jul 23, 2008 | Belkin Computers & Internet
ISP
I have a feeling I might be able to find the router setup information if you can tell me the correct answer to the prompts needing answered by this link
Virgin Media Broadband Help
The model number of the Belkin router may be of interest if detailed configuration instructions are required and because there is the a report of an issue with a specific belkin router model on the Virgin Media site that appears to require a firmware update to work well with that particular internet service.
Dec 13, 2007 | Belkin (F5D9230-4) Wireless Router...
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
