Question about kawasaki Full Suspension Mountain Bike Men
Have a 2002 kawasaki 650 prairie my son was riding all of a sudden it just stopped, engine was still running but no gears, display and reverse light are just flashing. It will start but cannot rev up and can put in all gears by moving atv but none are engaging. can anyone help??
Your belt is probably gone and the bike is in crawl mode
Posted on Aug 19, 2010
Hi, H650, working fine, then erratically just stop, seems electrical problem, side stand switch were suspicious, took it off and bridged the wires, the same problem, Thx
Hi, Tamas the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Runs stops starts backfires
Engine turns off all of sudden when riding
Kawasaki Ninja 650 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 01, 2017 | 2008 kawasaki Ninja 650R
Will idle & run at slow speeds, bogs down at higher speed.
Prairie 360 revs high but goes slow (45mph) - Kawasaki ATV Forum
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Oct 27, 2008 - 2006 Prairie 360, wife's ride, polar white, with 26" Swamp Lites on SS108's. ... that it has a low top-speed...45mph is about as fast as they seem to go. ....air cooled motor theres no real performance there, the P360 wts are light ... Can't put 2005 Kawasaki KVF 360 into gear
Jun 30, 2013
Prairie 360 speed/power issue?
Aug 28, 2012
06 Prairie 360, too many rpms???
Nov 30, 2011
2004 Prairie 360: WOT miss
Nov 9, 2011
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki 2005 Prairie 360
Kawasaki forum, I have a 2002 kawasaki prairie 650 4x4 that will not switch into 4 wheel drive. It stays in 2 wheel only. Help please
Honda FourTrax & Kawasaki Prairie 650 ' Outdoor Life
www.outdoorlife.com/articles/gear/.../honda-fourtrax-kawasaki-prairie-6...
Honda decided not only to get into the 500cc-class automatic 4x4 camp, but to do ...by three electronic shifting programs: one for high-speed driving on easy trails; ... this innovation: Kawasaki made the Prairie 650 capable of starting in gear.
Sep 12, 2015 | ATVs
I got a 2002 Kawasaki prairie 400 when I get it wet in the mud it dies have to wait ten min then it start back but u got to let it idel if u give it gas it dies
That is because the water is not a friend with electrics especially with coils, ignition coils and spark plugs. If water reaches the coils the engine will stop and it will run again when water is evaporating.
Oct 17, 2013 | 1999-2002 Kawasaki Kvf400c D Prairie 4x4...
2006 kawasaki prairie 4x4 model kvf 360 c belt indicator light reset
On the right hand side of the ATV just under the gear leaver, you will find a grey and black multiplugs, you will need to swap them. Please see the link below. KAWASAKI 360 PRAIRIE BELT RESET
Sep 23, 2013 | kawasaki 2012 Prairie 360 4x4
1987 kawasaki 185 bayou reverse light
No, the reverse light is only for reverse indication. If the light is coming on while riding in any forward gear there is a loose connection, probably where the reverse sender attaches to the transmission or the sender itself is malfunctioning.
Jul 08, 2009 | 1985 kawasaki KE 125
2002 Kawasaki Prairie 650
Either the switch on the handlebars isn't making contact. Or the shift motor on the front differential is broke.
Jul 06, 2009 | 1990 kawasaki ZZR 600
Need lower first gear for more serious off road use
Change your rear sprocket for a larger one ie 3-5 teeth more, or the front for a smaller one maybe 1 tooth less, that will give you more accelleration.
Jun 21, 2009 | 2007 kawasaki KLR 650
kawasaki Full Suspension Mountain Bike Men Logo
419 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Marvin
Marvin
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
