The time does not stay set on my laptop I have the battery just need to know the correct way I know the covers need to be seperated !!! I need instruction on how to do it please
  • 4,889 Answers
Ok it looks like you wanna replace the CMOS battery. Can I gave the make and model no of the laptop so that I can give you the dis-assembly instructions?
Posted on Jul 18, 2010
  • Robert Anthony
    Robert Anthony Jul 21, 2010
    thank you toshiba satellite p305d-s8828
  • eagle338
    eagle338 Jul 21, 2010
    Based on the config it is most likely to be under the keyboard.
    Considering the tricky nature of this repair, I would recommend that you go through this pictorial. You will need to remove the processor to be able to see the battery(the small blue circular package on the left side-see step 31)
    http://www.irisvista.com/tech/laptops/To...
Every time I power on my laptop, the date and time is set to years ago. I've changed it to the correct date and time a lot, turn it off when I'm done, but it goes back once I turn it back on. I have a...
You need to change the internal clock battery. It's referred as a CMOS battery or a system battery. It will most likely be a silver button cell...either a 2016 or 2032. You will most likely find it by removing the main battery and one of the bottom access covers. After you change it, boot up to Windows and change the time and date. It should now retain the settings.
Nov 05, 2013 | Gateway Computers & Internet
Bl51 motherboard
All laptops have a CMOS, or "Complementary Metal Oxide Semiconductor," battery.
The main purpose for the CMOS battery is to keep the system time, date and BIOS settings even if the computer is turned off or the main battery dies.
Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.Preparation
Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
Purchase the battery through Acer or a local or online computer parts dealer.
Turn the laptop off and unplug it.
Also unplug any external hard drives, cameras or other external devices.
Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Removal
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing.
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
Installation
Plug the new CMOS battery cable into the motherboard.
Slide the battery partially under the laptop casing to hold it in place, then align the cover with the slots on the bottom of the laptop housing.
Replace the screws, then turn the laptop back over.
Settings
Plug the laptop in and turn it on.
Enter your BIOS (usually by pressing "F1," "F2," F10" or the "Delete" key) before the operating system loads.
Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
BIOS Reset
Any time the CMOS battery is unplugged for more than a few seconds, your BIOS will be reset to the default manufacturer settings.
If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3-5 seconds to correct the problem.
http://support.acer.com/us/en/default.aspx
Acer aspire laptop battery replacement
http://www.youtube.com/watch?v=mQTZ1AUR0uw
Jul 24, 2013 | Acer Aspire 5100 Notebook
The system clock will not stay set, when I turn off laptop the clock stops and calendar stops . I reset it every time I turn it back on so I receive all up to date updates . Windows updates are set to ...
You need to set the correct date and time in your system BIOS. To access that you need to press the correct key when the computer is first booted (usually DEL or F10/F2/F11).
Most computers will have a message stating press xx Key to enter setup or etc.
If this problem persists even after setting the correct time in your BIOS, your laptop needs a new CMOS battery. I recommend having a professional do this.
May 09, 2011 | Acer Aspire 6920-6422 Notebook
Computer clock will not stay set. I was told the motherboard battery may be dying.
You are right .
First you should follow the dissembling from the bellow link and then after do it .
http://www.youtube.com/watch?v=pPdw-pkS88k
Hope this helps you.
Jan 10, 2011 | Acer Aspire 9410 Notebook
If i leave it for 15 min it automatically grt shutdown?
go to your control panel (from teh start menu, or round blue icon in the bottom left corner) and look for power options. you can customize power settings in there, most laptops are set to go into suspend mode after sitting for a while to save power. you can set the amount of time that it waits before suspending itself, when its plugged in you can set it to stay on all the time. there are seperate settings for when it is on battery as well.
Dec 09, 2009 | Acer Aspire 4530-5889 Notebook PC
The time and date has to be set after shutting off.
The BIOS battery keeps the Date and Time correct, if the battery is flat the date and time will be wrong or you will get an error date and time error.
You need to replace the battery with a new one. Your friendly computer shop can help you if you don't know how to change the battery.
Sep 28, 2009 | Dell Latitude C600 Notebook
Dell inspiron 700 power won't stay
Thats a fairly easy problem. The problem is that your laptop is not recieving enough voltage to keep your battery charged. Your adapter is more than likely the culprit and needs to be replaced not the battery. You can also start by going to click on start, then control panel, performance and maintenance, then power options, and then configure and make sure your power options are set correctly. Thats should fix you up!
Jun 09, 2009 | Dell Computers & Internet
Safety 1st pink corvette
Below the radio is a panel held on by two knobs labelled "driver" and "passenger." Unscrew these knobs to get to the radio battery cover. Remove the battery cover with a phillips screwdriver and replace the batteries.
Aug 05, 2008 | Toys
Computers & Internet Logo
12 people viewed this question
Alun Cox
David Payne
David Payne
