Question about Haier BC112G Wine Cooler
I have a HVF042ABL that is no longer cooling. The motor was very warm to the touch when I unpluged the unit. Can I repair the unit? How do I check the coolant as wellZ?
  • 1,284 Answers
Hi, it sounds as if low freon in your compressor since the motor is warm and the unit is not cooling.
Take care
Posted on Jul 18, 2010
  • charely_odwo Jul 19, 2010
    How do I replace or recharge the freon and check for leaks?
  • Shehu Pro
    Shehu Pro Jul 19, 2010
    Hi, you legally can't unless you are e.p.a. certified to purchase the type
    of freon in the unit and you have the equipment to do so, by law you
    need to evacuate the sealed system, then pressurize system with nitrogen
    and a small amount of r22freon, find the leak,recapture nitrogen/r22 and
    repair leak,then recharge unit with correct amount of correct
    refrigerant it needs, the equipment to do so is expensive too
Fridge is not cooling at all.
Usually cheaper to buy a new one this time of year over a repair. Unless you have appliance insurance. Sorry for your problems.
Nov 30, 2017 | LG LFX31925ST
I have an gss221ibma side by side. the freezer no longer freezes but the refrigerator works. Also around the doorframe of the freezer it is quite warm and sometimes hot. please help.
Hello, pull the unit out away from the wall remove the cardboard or metal cover down the bottom which will give you access to the compressor area. Assure that the compressor fan motor which is the fan that cools the compressor is running if it is not then you will have to replace the compressor fan motor. Unplug the unit until the compressor cools if you leave the unit plugged in for a long time you can cause damage to the compressor itself. . If you do not have another place to store your food until you get the new compressor fan motor leave that cardboard or metal panel off the unit if you happen to have a large box fan put it in back of the unit this will cool the compressor until your new part arrives. I have had to wait 8 days for a compressor fan motor at one time and the customer I repaired the unit for had no other place to store there food. Note this fan has to be constantly running on the compressor until you are able to replace the compressor fan motor. If you have any further questions message me back Thanks
Rick
p.s make sure you have your model number when you order your part I tryed looking that model number up but it did not come up on the look up site if you need me to locate the part number that you would use to order the compressor fan motor message me back the make and exact model number of your unit Thanks again
Sep 08, 2011 | GE Refrigerators
I addred coolant to the AC unit a few weeks ago and it has been running fine until last night. I went to check the pressure and make sure the line was not frozen this morning since the indoor air climbed...
It is just coincidental that the fan motor died now...
Replace the condenser fan motor and you will be good again...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 20, 2011 | Carrier 38CKC036 Air Conditioner
Both refrigerator and freezer have stopped cooling. The compressor sounds like it is working and then will stop. The fan is working. The copper pipes coming from the compressor are hot/warm to the...
This sounds like your refrigeration unit is low on charge...there probably is a leak in the system...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 25, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Fridge/Freezer working sometimes. Starts and stops
Need you to check the compressor to see if too hot to touch. If so unplug and don't leave it plugged in until we find the problem. This could be start capacitor, start relay, overload or a bad condenser or evaporator fan motor. Like to know he model number to help you better, Let me know, Sea Breeze
Jul 21, 2009 | Refrigerators
No longer cools.
This refrigeration system may be under extended warranty.
Otherwise check the compressor start relay for loose or burned contacts.
Mar 08, 2009 | Avanti WC494D Compact Wine Cooler Beverage...
Humming sound unit does not cool
sounds like abad compressor, when it heats up its overheating and shutting off,i would check if the fan behind, next tot he compressor is blowing, and the lower coils are not cloggged
Jan 25, 2009 | Frigidaire Refrigerators
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2008 | Frigidaire FRT18G4A Top Freezer...
Haier BC112G Wine Cooler Logo
129 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
