Question about Canon PIXMA iP5000 InkJet Photo Printer
Waste ink tank reset
Waste ink absorber reset , ink tank holder will not center, so as to replace empty tank.
thank you.
    President:
  • 2,571 Answers
Google is your best bet for a question like that, where did you get the instructions to reset the waste ink absorber?
Look there also
Posted on Jul 18, 2010
My canon printer 1p 1000 says the waste ink absorber is full contact service center
hi
you need to replace the absorber waste container. But to ensure you can work around this, do this first. Remove the square rubber at the end of the right side of your printer. Use cotton cloth absorb the waste ink. Clean and wipe the ink around area and place the absorber back into the tray.
Finally clean your print head by using dry cotton swab. If this deosnt work, try this: if it doesnt solve the issue, you must replace absorber waste ink tank .
  • You can manually override it, but I recommend getting it replaced.
    Reset waste ink tank counter CANON PIXMA iP 1000
    Disconnect printer from AC power
    Press and HOLD the POWER button, and connect printer to AC power
    release the the POWER button
    Press the POWER button again
please send me 4 thumbs up
Jul 20, 2011 | Office Equipment & Supplies
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
Screen shows picture of printer cartridge holder and message "waste ink absorber is almost full"
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
May 21, 2010 | Canon PIXMA iP90 Mobile Printer
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
5) Select OK
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink error message, now the printer won't print until the waste ink tank is emptied or replaced.
Jan 11, 2010 | Canon PIXMA iP90 Mobile Printer
Full ink absorber
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
Canon multifunction printer
I believe that he is reffering to the waste ink tank where the cartriges stop to the right when not being used. There are two small foam pads over there.
I cleaned mine by opening lid and have carriage run to the left, then I reach in with a q-tip and press down repeatly until q-tips are almost clean. You will need a flashlight to see waht you are doing.
Feb 18, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon iP2000 Waste Ink Absorber - where is it for washing and replacing?
I found it under my ink cartridges in my Canon iP2000 printer. Trying to losten it for cleaning, it came out in my hand, I washed it and replaced it with a tiny amount of glue. After resetting the program, it is working again.
Feb 11, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon ip 1000 waste ink reset
want the software tool to reset the waste ink level for canon inkjet printers
Apr 20, 2006 | HP LaserJet 1020 Printer
Canon PIXMA iP5000 InkJet Photo Printer Logo
764 people viewed this question
old marine
old marine
