Question about Belling DB90 Electric Kitchen Range
My Belling G741 main oven is now not responding to the control.The flame is not increasing and getting any warmer
SOURCE: Belling DB3 Main oven door falling off its hinges
The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
Posted on Mar 14, 2008
Illeagle
  • 525 Answers
SOURCE: Belling Countrychef, main oven will
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
  • 833 Answers
SOURCE: Oven will not respond
The knob won't have any effect on the flame size.  The knob controls temperature.  If you're referring to the pilot light staying on and then the main flame not going on...that's another problem.  If the main flame will not go on, the assembly that controls the main flame is likely defective.  If the unit has a thermocouple, you might change it out first.  Sometimes, that's all that is needed and they're cheap.
Posted on Nov 26, 2008
SOURCE: main ovens dont work
if the clock is not set the ovens wont work,they dont have to say the right time but they do have to have a time. to set the clock hold the hand button and the clock button(first two buttons),and then plus or minus to set the time
Posted on Feb 05, 2009
  • 160 Answers
SOURCE: Gas oven
Its the flame failure device faulty (FFD)
Posted on Feb 22, 2009
Chef Regency Gas Wall Oven - oven fan working,light working , grill working as well but the main oven not responding when turning dial. The Piezo ignition is intermittent and no gas sound coming out.
The Piezo control board opens the gas valve while it makes a spark. Once the flame is lit the milivolt flame sensor holds it open from there on. Replace the piezo control board to fix.
Jan 16, 2016 | Kitchen Ranges
My belling wall oven model number 444440560 keeps going out after only a few seconds ignition how can I fix this thNks
which is going out top or bottom? may want to check the oven safety valve though it does not normally go out compared to other components. may have a bad igniter ( does it glow or lite up at all) it may still glow but not put out enough current to ignite flame? check with multimeter as well. if oven top is going out also check the igniter model or infinite switch
Mar 10, 2015 | Belling Ovens
Have a Belling GT755 and when I press the knob for the oven it ignites, but then when I release the knob the gas/flame goes out. I am having to keep the knob pressed in with a mop head or adjustable...
The oven has a flame detection installed that makes sure the gas turns off if the flame goes out. There are two component that do this. One is the flame detector and the other is the control device that turns the gas off,. Either one of these cold be faulty. The cheapest way is probably to replace the detector in the oven and if that does not work, replace the gas control device.
Jan 03, 2018 | Belling Solitaire G755 Gas Kitchen Range
Belling Farmhouse Cookcenter Model 111 main oven wont reach temp
Same problem here too. Plus the in-game assisted oven has a similar problem inasmuch as the flame goes straight to max and won't reduce. Please help
Apr 05, 2010 | Belling FarmHouse 931 Gas Kitchen Range
Belling G755 Cooker oven wont stay lit
I'll give this a go! With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically. However, you are having to try and manually keep the gas going for a good five minutes. I would think that there is either a problem with the thermocouple or the gas control valve! Tony www.birminghamelectricsltd.com
Jun 18, 2009 | Belling Solitaire G755 Gas Kitchen Range
Nov 23, 2008 | Rangemaster 110 (Gas) Kitchen Range
Belling DB90 Electric Kitchen Range Logo
105 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
