Question about GE Refrigerators
I replaced the door gasket on a TBX20, but now the
I replaced the door gasket on a GE TBX20 fridge, but now the door will not close at the bottom. It is as if the lower part of the door is warped.
  • wkb8873 Jul 18, 2010
    I have already added washers to raise the door.
  • 532 Answers
The gasket was not properly replace. Here is a simple way to fix it. You can do this yourself very easily.
When installing a new gasket, push the gasket bead under the gasket retainer with your fingers. Refrigerator doors tend to warp when the gasket retainer screws are loosened. To correct this, realign the door by hand after installing the new gasket. To straighten a warped door, pull at the bottom and push at the top, or pushing at the bottom and pulling at the top should fix this problem. Close the door to check the alignment.
Repeat as often as necessary, then tighten the gasket screws.
To remove the gasket, loosen all retainer screws and pull it out from behind the gasket retainer. Do not remove all the screws. If the new gasket is crimped from being packaged, place it in warm water until it regains it's original shape. It should lie flat around the door when applied and tightened. If it doesn't, remove the gasket and start over.
Gaskets are inexpensive and it's a good idea to check your refrigerator gasket after several years of ownership. If it is cracked, gets mildew constantly, replace it.
Thanks for contacting Fixya.
Posted on Jul 18, 2010
    Warpage seems to be the problem. Your re-algnment suggestion seems to be working. I am still testing.
  • 360 Answers
Hi, GE refrigerators have plastic cam risers on the bottom of the door to help close and stay shut, if they break you will have this problem with the door, look at the bottom of the other door and you will see what I mean!
Take care
Help to restore 1954 GE fridge door gasket. The gasket brackets are missing.
Hello Karen
Try somewhere like this
Refrigerator Parts
Gaskets for Antique or Vintage Refrigerators - YouTube
? 4:55
https://www.youtube.com/watch?v=39IRu2ATUA0
Jan 27, 2011 - Uploaded by AntiqueAppliances
... on two doors, no locks on the doors and not have the back cover. Do you have any pictures of this this ...
IMAGES
1954 GE fridge door gasket Google Search
Dec 01, 2017 | GE Refrigerators
The fridge door won't close all the way , is there an adjustment on the hinges
Check the bottom fridge door hinge. There should be two plastic cams, one that mounts to the door and one that mounts to the hinge. From your discription it sounds as if thoes cams have broke and need to be replaced
Sep 01, 2011 | Maytag MZD2766GES Side by Side...
Plastic latch on left french door broken
Go to www.partselect.com put your model number in, click on the diagram. For the door. Should be part #PS1016086
/uploads/images/9_1_2014_3_03_11_am.png
Jan 30, 2011 | GE Profile PFS22SBSS Bottom Freezer French...
Top lock on GE Profile Fridge is broken
bad news you have to replace the door gasket
they only sell them in pairs and not cheap
Jul 03, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Top freezer door pops slightly open when frig door is closed
try to adjust hinges and check the door gaskets for pinching. Also I have seen that if the fridge is slightly pitched forward and not slightly towards the back gravity sometimes this causes the problem you describe.
Apr 26, 2009 | GE Refrigerators
GE fridge GSH22KGMA not getting cold
you need to replace the gasket on the unit . its letting in too much moisture.. the drain line may also be clogged up and holding water in the drain pan. take a piece of wire and clear the drain then poutr hot water and baking soda down it witrh a turkey baster.
Apr 05, 2009 | Refrigerators
On my GE Profile side by side the Fridge side the door will close and then pop open. The door has been making a clicking sound when opened. When it pops open it does not close again.
This can happen if the door gasket is not seating properly. If it is deformed you can correct this by pouring boiling water along the deformed area, then closing the door and keeping it closed while the gasket cools and sets. Please check first that it has been correctly installed, there are screws and a bracket behind the gasket. Another problem could be the alignment of the door. It is possible to adjust alignment on the hinges. One other thing is to raise the front "feet" so that the fridge slightly leans backwards.
Mar 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer door is canted forward. This separates the gasket from the frame and allows air in. Large amount of frost build up.
HI thanks for the question. the fridge door should close by itself if opened and then just let go of door. if not that way. raise the front of the fridge to make it work that way. thanks the appliance doc. please rate my answer. thanks.
Aug 11, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
