Question about Ruud UAMB Air Conditioner
The compressor will turn on for approx. 5 seconds and then cut, I have been told the compressor is bad, but it is only 6 years old...
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
Sounds like the compressor is shuting of on inernal thermal overload. Sorry that it's only 6 years old. More sorry that a typicall warranty is 5 years. In my area a typical replacement compressor, installed, will run between $1,500 and $2,000. A new condensing unit, if available, will run $1,000 more. Either way, make sure that the contractor explains to you, exactly how he intends to make sure that the system is cleaned, as this type of failure is typically a slow burn and is of the worst tyoe, most subject to repeat failure if not done properly.
Posted on Jul 19, 2010
21 year old GE TBX18SLS top freezer refrigerator. Stopped cooling completely and lost all food in fridge/freezer. Cleaned out underneath and found compressor and fan turn on but only stay on for approx...
Yes that does sound like very likely the relay is bad,by removing it from the compressor and turning it upside down you can test it using a ohm meter. When turned upside down the meter display should be ZERO ohms resistiance. Also the thermodisc overload should be ZERO ohms when measureing it on the wire that slips onto the compressor pin and on the other wire . Oh to measure the relay the meter leads go into the 2 terminals where it plugs onto compressor.
NOW the bad news the original parts are no longer available,but their is a aftermarket relay/overload combo that would work its sold under the SUPCO name brand and is part number RO41 it should be available at your local appliance parts store or online at;
repairclinic.com
apdepot.com
partselect.com
apwagner.com
Good luck,
GENE
Aug 27, 2011 | Refrigerators
(8 Bravda old. air condion inoperative Freon
how do you know freon is ok it sounds like it is low and the low pressure switch is cutting compressor off and back on
Mar 24, 2010 | 1998 Oldsmobile Bravada
My model ACD2234HRQ is approx 90 days out of
you need to replace the rtc overload contactor located on the compressor body,there is also a run capacitor on the contactor,replace this along with the rtc contactor,this is your problem,the contactor and overload give the compressor starting power and run power to the windings,if the capacitor is bad it doesnt have enough torque to overcome the power to turn the compressor initially
Mar 13, 2010 | Amana 22.6 cu. ft. Side-By-Side...
I have a 10+ year old Kenmore side by side that quit cooling
the starter unit of the compressor can be bad EZ fix if it is that...its the element conected to the compressor :)
Dec 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Buzzing compressor
heres a part number for the overload relay assy 5304468029.. its mounted on the side of compressor. its a tricky one, usually my experience has been the noise comes from a bad compressor( which you should have 5 year full warr from manufacture). sometimes the overload relay does go bad preventing compressor from starting,the n ew compressor will come with a new overload relay
Nov 19, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Kitchenaid freezer will not stay frozen 5 years old
it might be your thermostat stucking up...the one your adjusting one notch higher...
Mar 28, 2008 | Refrigerators
Candy cpca240ffk compressor running.
i don't have a diagram but im familiar with that problem its either a bad relay on the compressor a bad thermal over load in the relay box mounted on the compressor terminals or a bad compressor don't know where you live im in usa here you can get an after market relay with a start capacitor and if its not the compressor will fix the problem
Jan 10, 2008 | Candy CPCA240FFK Bottom Freezer...
Freezer problem
Not sure of what cut out refers to. If you mean the power supply is tripped out after twenty secs hen I would say there is a fair chance of the compressor being down to earth (ie broken). If you mean that the compressor tries to run and then stops after twenty secs then there is a fair chance the compressor is stalled (ie broken). There is also a chance that the relay (starting device) may be at fault failing to start the compressor. If it is the relay then the cost may be around £70 if its the compressor then you are lookin at a couple of hundred pounds approx. The buzzing sound does sound like the compressor trying to run but stalled and unfortunately compressors have no real average anymore and are prone to fail whenever they choose to. Sorry to sound negative and hope this helps.
Sep 03, 2007 | Freezers
Compressor turn on briefly, no water collected
Sounds like the low pressure cutout switch is stopping your compressor running, especially if the "6 seconds" you mention are exactly the same length. Not enough refrigerant would be the usual cause, but the reason for the refrigerant loss is harder to tie down - possibly a seal or a loose valve seat or even a pinhole in a copper tube. Best solution now would be to take it to a refrigerator mechanic to top it up and check for leaks - get a quote first to check - 'fridge gas is getting costly. Other possible solution is that the low pressure switch itself is faulty, relatively inexpensive to replace (but unfortunately you will need at least a partial gas recharge on most types of system after) - your fridge gas guy will be able to check very easily if there is adequate gas in the system, and should check this low pressure switch if there is not.
Feb 25, 2007 | Maytag M3DH30B2A Dehumidifier
Ruud UAMB Air Conditioner Logo
110 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
