Question about Dell Inspiron E1705, Intel Core 2 Duo T5300 , 17" WSXGA+ LCD, 1GB DDR2 SDRAM, 256MB ATI V... PC Notebook
Diagram how to connect dell inspiron laptop 9400 and record tv programs
  • 2,571 Answers
If you have the right Hardware (Digital TV tuner card) it will have come with the software needed.
If you dont yet have tv tuner card, thats what you need
Posted on Jul 18, 2010
SOURCE:
Charging light is flashing
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Jan 07, 2013 | Dell Inspiron 9400 Notebook
Need a password for dell inspiron 9400 service tag #HNCKCC1-595B
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.Click on one of these links todownload HIREN'S BOOTCD :-http://www.hirensbootcd.net/http://67.20.82.163/
May 10, 2012 | Dell Inspiron 9400 Notebook
Usb2.0 laptop tv tuner driver
http://www.inetbridge.net/forum/download/file.php?id=2295&sid=432f7c52d98676c2400b20b83f88c355
Dell Emuzed Angel USB TV Tuner Driver v.1.0.2.32 A00 Windows XP.
Supported Models: Inspiron 6000, Inspiron 9400/E1705, XPS/Inspiron XPS Gen 2, Inspiron 9300, XPS/Inspiron M170, XPS M1710.
Driver : Dell Emuzed Angel USB TV Tuner Driver v.1.0.2.32
Mar 01, 2011 | Computers & Internet
Bios Password dell inspiron 9400
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-9400-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 14, 2010 | Dell Inspiron 9400 Notebook
Dell inspiron 9400- constant clicking noise like a mouse click locks computer
Probably a loose connection. Disassemble, check components, the reassemble.
Mar 12, 2010 | Dell Inspiron 9400 Notebook
Can't activate wifi key on inspiron 9400. fn f2
Try to uninstall then re-install the Dell Quickset from the Drivers and utilities disc.
Oct 29, 2009 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 display
you may have damaged the screen in which case theres not much more you can do then replace it.if its a new labtop it may be still under warrenty in which case get back to dell.
Mar 22, 2009 | Dell Inspiron 9400 Notebook
How do I add a dell external monitor to a dell inspiron 9400
Simply use the external video port. It may require an adapter depending on the monitor you plan to use.
Nov 18, 2008 | Dell Inspiron 9400 Notebook
SVIDEO OUTPUT PORT - Is there a possible way to change it to input via the settings on my computer?
that's a S-VIDEO OUTPUT port only - sorry you'll need a USB adapter to record video.
Mar 26, 2008 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 PC Notebook replace hard drive
On the underneath side of the notebook there should be two screws that are usually labeled with a picture of a drum. Remove tham and the drive should slide out. Remove the drive from the tray you slid out and reverse procedure to re-install.
Jan 31, 2008 | Dell Inspiron 9400 Notebook
Dell Inspiron E1705, Intel Core 2 Duo T5300 , 17" WSXGA+ LCD, 1GB DDR2 SDRAM, 256MB ATI V... PC Notebook Logo
239 people viewed this question
Clive
Clive
Alun Cox
