How do I get my wireless speakers to pick up the signal? I have wireless Sharper Image indoor/outdoor speakers and I have plugged them in outside and inside but cannot get the signal to pick up.
  • 616 Answers
Play with the antenna placement, much like you would if trying to p/u tv signals.
Posted on Jul 19, 2010
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
Jun 23, 2015 | Equity Time USA 31215 Wireless Outdoor...
Sharper image indoor/outdoor wireless speakers and transmitter has no audio.
First, determine if the TV device is putting out sound by plugging in a headphone into the audio out of the TV. If audio is there then the
transmitter and wireless speakers system may be at fault.
You can also plug in a CD player playing a disc into the transmitter to see if that source then transmits the audio.
Aug 21, 2012 | Audio Players & Recorders
How do i make the Sharper Image SA251 Subwoofer Speaker work what do i use as a line level?
I don't suppose they came with a manual.
http://www.spreadmyad.com/san-diego/merchandise/electronics/8242133-sharper-image-subwoofer-san-diego-25
Line level would (usually) be the LFE signal produced by a multichannel receiver. The speaker level inputs would be from the Front L and R speaker outputs.
Aug 04, 2011 | Sharper Image SA251 Subwoofer
Have outdoor speakers but will not play sound, they are connected to a xantech pa1235x and the indoor speakers work but not the outside ones
Check the reciever and verify if you have a selector swicth pressed for A speakers and B speakers and see if this helps...
Some recievers will only power A or B, not both at the same time.
Lets not assume your outdoor speakers work. Would be helpful to know if you have tried to disconnect the inside set and plugged the outside speakers in those stereo jacks. If no sound, your speakers may have loose wires on the inside of the box/cabinet/case or they could be no good period.
If they do work, and the system does not provide all four jacks to be powered at the same time. You may consider buying a pair of piggy back rca jacks. Plug in the indoor and outdoor speakers into the same connectors the indoor ones are on now.
That way at least you can run them all at the same time from the speaker connector where you have the indoor speakers hooked up..
Hopefully you'll find something useful in this
Good Luck
Respectfully
Jun 09, 2011 | JBL N24AWIIBLK Speaker
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
I have a 900 MHz Wireless Indoor/Outdoor Mono(Accurian)
yep the power to it is in question and since it is a 9 volt adaptor as mentioned that will need to be checked 9vdc adaptors are over the counter items in most radio shops
Jul 29, 2009 | Audio Players & Recorders
Wireless speakers to audio devices having no audio output
you can find all kinds of adapters for RCA or phone jack to anytype of connectors at best buy or circuit city, if not Radioshak probably have them. just ask for a cable adapter to the type of connector transformation you need for the speakers.
Dec 30, 2008 | Computers & Internet
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
We have the sharper image wireless indoor outdoor speaker and when we plug everything in there is nothing coming out of the speaker. Are we able to get it to pick up satellite radio?
The wireless speakers do not pick up a wireless signal outside of the round wireless broadcaster that came with the speakers. You will need to connect that to your satellie radio to broadcast to the wireless speakers. Make sure the wireless broadcaster component is plugged into the sound source you want to make wireless. After you've connected the broadcaster to the sound source and turned everything on then push the Auto tune button to connect to the broadcaster and recieve the sound.
Nov 27, 2008 | Audio Players & Recorders
Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Jul 19, 2008 | Audio Players & Recorders
579 people viewed this question
 Grubhead
Grubhead
