Question about Panasonic NN-P295SF Microwave Oven
Mi panasonic prestige inverter microwave will not
A panasonic prestige inverter microwave when I put mic on regardless of how much time it shots of after 3 seconds. Any ideas
  • Panasonic Master
  • 9,098 Answers
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Nov 23, 2011
The settings on my microwave appear fine. Then I set the time for let's say 50 seconds and it turns off in 5 - 9 seconds. Then what you see is the correct time --- no other message.
If this is an inverter oven, it could mean that there is a problem on the inverter board. Testing these boards is fairly simple. You just need to find a service manual for that model.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jul 18, 2016 | Panasonic Genius Prestige Inverter...
How do i set clock
hit the clock button,
type the time with the number pad
hit clock again.
done.
Mar 07, 2015 | Panasonic Genius Prestige Inverter...
My panasonic genius prestige inverter microwave has started to click off after I enter the power & time. Sometimes it will work fine. Sometimes it takes 2 or 3 times of entering then cleaing the i
Check the door latch switch inside the oven. The 4 switches where the door hooks latch on to when the door is closed has to engage with the door hooks to tell the oven that the door is closed. loosen the 2 phillip screws that holds the switch assembly and slide it to adj. and ensure that the switches close when the door is closed.
Sometimes the switches go bad and cannot make contact and must be replaced. If you see that the connectors on the switch is discolored or overheated replace the switch, it is bad.
Jan 15, 2015 | Panasonic Genius Prestige Inverter...
How do I turn off the Demo mode
Press the timer/clock button 4 times. That should disable demo mode.
Oct 20, 2014 | Panasonic Genius Prestige Inverter...
Panasonic inverter 900w microwave fault code h97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Sep 14, 2012 | Panasonic Genius Prestige Nnsd997s...
Panasonic nn-sn778s microwave shuts off and no heat- H97 is error code
Aug 21, 2012 | Panasonic Genius Prestige Nnsd997s -...
Microwave inverter technology - better now? I am considering one of Panasonic's new 2009/10 Prestige units. Panasonic's explanation of the benefits of inverter technology to produce more even heating is...
An inverter-based unit is more efficient and uses less power than a design based on a high voltage transformer.
But with increased complexity / higher component count comes a statistically higher chance of failure, especially in inverter circuit boards that are machine soldered, where sometimes not enough solder gets on parts that are large, run hot, and/or run with high currents. This can lead ot bad connections and blown components.
As a longtime technician, I have always liked Panasonics very much, but I have never been a huge fan of inverter-based designs due to those factors. But again, as a technician I repair my own stuff, so it's not a big deal. And everything is slowly moving that way anyway.
I would not at all discourage you from buying an inverter-based Panasonic, but this is one of those rare times when I would advise you buy an extended warranty with it.
Once it's out of warranty, if it fails, call around and look for a repair shop that has a technician who does "component-level repairs" on circuit boards, instead of just changing boards. That will save you on repair bills.
It's often best to find a TV shop that also does microwaves, instead of an "appliance service center" which does not work on electronics.
You can find authorized Panasonic servicers here. Bookmark that for later.
Jan 15, 2010 | Panasonic NN-S541 Microwave Oven
Error code H-98
Dec 01, 2008 | Panasonic NN-P794SF Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
254 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
