Question about Microsoft Windows XP Professional
Internet Explorer Script Error message constantly occures
Seems like everytime I switch pages or sites the above message is posted along with Line:.....Char:...Error: object doesn't support this property or method.... Code:...
  • 428 Answers
I have posted a Tip in Fixya with the solution Solution Link Please be kind enough to RATE the answer as well as the Tip!
Thanks for contacting Fixya!
Posted on Jul 19, 2010
Keep getting a box popping up talking about script errors. how do we stop that?
If you use Internet Explorer as your Web browser, chances are you have experienced, or will experience, popup script errors. Typically, a dialog box may appear stating "A Runtime Error has occurred. Do you wish to Debug?" or "Internet Explorer Script Error. An error has occurred in the script on line 1. Do you wish to continue running scripts on this page?" These errors can be distracting and interfere with your Web browsing experience. If you would like to stop receiving these error messages, you must modify your IE settings.
Open IE, select "Tools" and ten choose "Internet Options." The Internet Options dialog box will open. Click on the "Advanced" tab, scroll to the "Browsing" section and then select the "Disable Script Debugging" box.
Clear the "Display a notification about every script error" box under the same section if it has been selected. Click "Apply" and then choose "OK" to modify your IE settings. You will receive no more IE script error notifications. Hope this helps.
Jan 01, 2013 | Microsoft Internet Explorer 8
Script error while going to yahoo chat room
First try to enable scripting through Internet Explorer
Go to Internet Explorer,
Click "Tools"
Click "Internet Options."
Click "Security" tab.
Click "Custom Level" button.
Scroll down to "Script ActiveX.controls marked safe for scripting"- enable
Scroll down to "Scripting - Active scripting" - enable
Scroll down to "Scripting of Java applets" - enable
Click OK
Click OK
I hope it will work.
Please let me know.
Thanks.
Mar 31, 2012 | Yahoo Messenger
Running script error
Method 1: Disable script debugging loadTOCNode(3, 'whattotry'); If the only sign of a problem is the error message, and Web sites are working, you can probably ignore the error. Also, if the problem only happens on one or two Web pages, it might be a problem with those pages. If you decide to ignore the errors, you can disable script debugging.
Note If this problem occurs on more than one or two sites, do not disable script debugging. Go to method 2 now.
To turn off the Scripting Debugger in Internet Explorer 6, follow these steps:
  1. On the Tools menu, click Internet Options.
  2. On the Advanced tab, click to select the Disable script debugging check box. and then click OK .
To turn off notification about every script error in Internet Explorer 7, follow these steps:
  2. On the Advanced tab, click to clear the Display a notification about every script error check box, and then click OK.
Method 2: Test a Web page from another user account, another browser, and another computer loadTOCNode(3, 'whattotry'); Use another user account, another browser, or another computer to view the Web pages that triggered a script error to determine whether the problem persists. If the script error persists, there may be a problem with the way the Web page is written. You can probably ignore the error and disable script debugging as described in method 1.
If the script error does not occur when you view the Web page from another user account, browser, or computer, the problem may be caused by files or by settings on your computer. Go to method 3 to continue to troubleshoot. Method 3: Verify that Active Scripting, ActiveX, and Java are not being blocked by Internet Explorer loadTOCNode(3, 'whattotry'); Active scripting, ActiveX, and Java are all involved in shaping the way information displays on a Web page. If these are blocked on your computer, it may disrupt the display of the Web page. Reset the Internet Explorer security settings to make sure these are not blocked. To do this, follow these steps:
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. In the Internet Options dialog box, click the Security tab.
  4. Click Default Level.
  5. Click OK.
Note ActiveX controls and Java programs are turned off at the High security level in Internet Explorer.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to Method 4. Method 4: Remove all the temporary Internet-related files loadTOCNode(3, 'whattotry'); Every time that you open a browser to view a Web page, your computer stores a local copy of that Web page in a temporary file. If the size of the temporary Internet files folder becomes too large, some display problems may occur when you open Web pages. Periodically clearing the folder might help resolve the issue.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 6, follow these steps:
  3. Click the General tab.
  4. Under Temporary Internet files, click Settings.
  5. Click Delete Files, and then click OK.
  6. Click Delete Cookies, and then click OK.
  7. Under History, click Clear History, and then click Yes.
  8. Click OK.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 7, follow these steps:
  4. Under Browsing History, click Delete, and when you are prompted, click Yes to confirm.
  5. In the Delete Browsing History dialog box, under Temporary Internet Files, click Delete Files, and when you are prompted, click Yes to confirm.
  6. Under Cookies, click Delete Cookies, and when you are prompted, click Yes to confirm.
  7. Under History, click Delete History, and when you are prompted, click Yes to confirm.
  8. Click Close, and then click OK to close the Internet Options dialog box.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to method 5. Method 5: Install the latest service pack and software updates for Internet Explorer 6 or Internet Explorer 7 loadTOCNode(3, 'whattotry'); If you do not have the latest service pack or software upgrades for Internet Explorer 6 or 7, download and install them. They may contain updates that can help resolve the issue.
Jul 06, 2010 | Computers & Internet
Windows int. explorer keeps closing saying java script error
This article offers five methods that you can try to resolve the issue, and also presents some advanced troubleshooting tips that you can try. Try each method in the order presented until you resolve the issue. If one method does not work, try the next.
This article is intended for a beginning to intermediate computer user. You may find it easier to follow the steps if you print this article first.
  5. Click OK.
  8. Click OK.
To install Internet Explorer 6 Service Pack 1, visit the following Microsoft Web site:
http://www.microsoft.com/downloads/details.aspx?FamilyID=1e1550cb-5e5d-48f5-b02b-20b602228de6&displaylang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=1e1550cb-5e5d-48f5-b02b-20b602228de6&displaylang=en) Note Internet Explorer 6 Service Pack 1 is recommended for systems that are running versions of Windows earlier than Windows XP.
To install the most current software updates for Internet Explorer 6 or for Internet Explorer 7, visit the following Microsoft Web site:
http://windowsupdate.microsoft.com (http://windowsupdate.microsoft.com) Please leave me comment, if you need further assistance Thanks for using Fixya Please rate this solution Rnj VinodKumar
Dec 15, 2009 | Sun Java Desktop System
How ca i remove the script error in yahoo messenger
You may have scripting disabled in your Internet Explorer.
To enable scripting:
Click "Tools"
Click OK
Click OK
Restart Internet Explorer
Still not working ? Update software
use the links on this page to help update software.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/notices/mstabuguqscripterror.html
After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
Start / control panel / programs
delete any old versions
Oct 04, 2009 | Yahoo Messenger
Hi, I keep getting this everytime I try to pay for something online by card. ''Navigation To Webpage Was Cancelled'' Any Ideas?
From Microsoft: "you may experience a problem when you visit some Web pages that are in different Internet Explorer security zones. When the problem occurs, you receive a message that resembles the following: Navigation to the webpage was canceled
This problem occurs if the navigation causes Protected Mode settings to change from On to Off. You can determine which Internet Explorer security zone a Web page is in by looking at the status bar at the bottom of the Internet Explorer 7 window.
This problem occurs because Internet Explorer 7 switches Protected Mode settings when certain Web pages are configured in the Trusted Sites area of the Security tab of the Internet Options dialog box. By default, Protected Mode is set to Off for Web sites that are configured in the Trusted Sites area"
Go here for the fix:
http://support.microsoft.com/default.aspx/kb/967941
Jun 20, 2009 | Computers & Internet
Internet explorer script error
hi its due to the virus problem in ur system that prevents u from accessing through internet.. When u are browsing it will automatically will display this script and it will get closed.. so better try to scan ur system..
thank u rate me
Feb 09, 2009 | Yahoo Mail
I CAN'T SEND A INSTANT MESSAGE ON YAHOO AS IT SAYS INTERNET EXPLORER SCRIPT ERROR. THE ERROR IS EITHER, NOT ENOUGH STORAGE TO COMPLETE THIS OPERATION, OR UNDEFINED
SYMPTOMS loadTOCNode(1, 'symptoms'); When you try to open any of the programs listed in the "Applies to" section, you may receive one of the following error messages:Internet Explorer script error - an error has occurred. Internet Explorer Script Error
An error has occurred in the script on this page.
Line: 574
Char: 2
Error: Class not registered
Code: 0
URL: msell2://c:&v=2&pid=ELLE00A&cmd=openitss&itssname=ell&path=home/home.htm
Do you want to continue running scripts on this page? uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); This behavior may occur if some Microsoft Internet Explorer files are damaged.uparrow.gifBack to the top
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this error message try rebooting your computer. If this doesn't work use the following methods in the order in which they are presented. uparrow.gifBack to the top
Delete temporary Internet files loadTOCNode(2, 'resolution'); Temporary Internet files are cached copies of the Web pages you access, as well as supplementary files such as graphic images and videos. You may find that Web pages you have accessed in the past take longer to load the first time you visit them after you delete these cached files.
To delete temporary Internet files, follow these steps: 1. Click Start, point to Settings, and then click Control Panel. 2. Double-click Internet. 3. On the General tab, click Delete Files.
Or, on the Advanced tab, click Settings, and then click Empty Folder. If this does not resolve the issue, go to the next method. uparrow.gifBack to the top
Reduce the number of colors Windows is using loadTOCNode(2, 'resolution'); 1. Right-click the desktop, click Properties, and then click the Settings tab. 2. In the Colors box, click a setting that is less than the current setting, click OK, and then click Yes.uparrow.gifBack to the top
Reduce the screen area loadTOCNode(2, 'resolution'); 1. Right-click the desktop, click Properties, and then click the Settings tab. 2. In the Screen Area box, move the Screen Area slider to a screen area that is lower than your current screen area setting, click OK, and then click Yes.uparrow.gifBack to the top
Use the default values for the security settings in Internet Explorer loadTOCNode(2, 'resolution'); 1. Click Start, point to Settings, and then click Control Panel. 2. Double-click Internet Options. 3. Click the Security tab. 4. Under Select a Web content zone to specify its security settings, click Internet. 5. Click Default Level. 6. Click Apply. 7. Repeat steps 4 through 6 for each Web content zone. 8. Click OK. If this issue continues to occur, go to the next method. uparrow.gifBack to the top
Repair Internet Explorer loadTOCNode(2, 'resolution'); To repair Internet Explorer, use the Internet Explorer Repair tool. To do this, follow these steps: 1. Click Start, point to Settings, click Control Panel, and then double-click Add/Remove Programs. 2. On the Install/Uninstall tab, click Microsoft Internet Explorer 5, click Add/Remove. 3. Click Repair the current installation of Internet Explorer, and then click OK.
Aug 23, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
