Question about Maytag NFW7200TW Front Load Washer
Amana NFW7200TW makes clicking sound at spin
Amana NFW7200TW makes a loud clicking sound when going into spin cycle. Turn drum fine when washing, pump removes water but it begins to make a loud clicking sound while trying to turn the the drum the opposite way for spin. Sounds like a transmission not going into gear.
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
  • 13433 Answers
SOURCE: extreme vibration of top loading
the clothes may be out of balance, redistribute the clothes around the washer and try again,
Posted on Oct 06, 2008
Karthik316
  • 187 Answers
SOURCE: Loud clicking during spin cycle = Maytag washer PAVT234AWW
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion....
Posted on Jul 20, 2009
SOURCE: We have a Maytag Epic Z front load washing machine
You better not to separate the inner and outer tubs as it's quite a job and takes a lot of effort.
Try to remove the heater on the very bottom of the front half of the outer tub. From outside it looks like an oval metal piece with a terminal on each side, a nut (or screw) in the center and a plug with 2 wires coming to it. UNPLUG THE WASHER as the heater is connected to the hot wire all the time.
Remove the nut (or screw) in the center of the heater and pull the heater out. Now you have a nice opening in the bottom between the tubs. There is a heater bracket, made of a thick wire inside. Make sure not to damage it when trying to remove whatever there is inside. Make sure the heater is aligned in the bracket when assembling it back together.
Good luck.
Posted on Oct 13, 2009
ginko
  • 19396 Answers
SOURCE: My Amana LW4303W washing made a loud bang noise,
Hi.
You have broken the drum bearing, it is the part located at the bottom of the tub, the drum bearing if fixed at the back of the drum.
Here all parts and diagrams for your model.
Regards,
Posted on Nov 14, 2009
Hi, I have an Amana front load washer NFW7200TW that will go through entire cycle but won't spin- cycle ends and clothes are very wet. Unlike the other posts I read, mine shows no error code nor does the...
I have a similar problem with a Kenmore top loader washing machine.It turned out a problem with the main shaft of the drum; it wears out and caused drag on it. at one point i installed a washer or spacer between the shaft and drum it worked for a while and the problem came back again. it is a mechanical problem and it is present with other brands that share the same drum and shaft.
Finally I end up buying a different brand this time a LG .
Mar 08, 2015 | Amana Washing Machines
How do I fix it?
Probably a loose balancing block. this the only thing that comes to mind.
Oct 28, 2014 | Amana Front Load Washing Machine Washer...
Washer will not advane from wash to rinse
It sounds like, when the dial gets to the pump stage, the contact expected to pump the water out isn't making contact. That could be a burnt contact within the controller, or a loose wire to to the pump from that section of the controller. Once the weight, or water level was low enough from your pumping it out, the sensor that checks the level/pressure allowed the spin. The problem could be on the control board too.
Here's an incomplete schematic I found:
http://www.doityourself.com/forum/electric-large-kitchen-home-appliances/474475-front-load-washer-amana-model-nfw7200tw.html
Jan 02, 2014 | Amana Front Load Washing Machine Washer...
3E error during rinse cycle on Amana NFW7200TW washer
E3 Error: Machine control is attempting to drive the motor but is not seeing any tach response. Visual check shows motor is not moving. (Locked, Hall Sensor fault). The hall sensor is a circuit in the motor. the motor will need to be replaced. Here is a link to the motor.
Oct 18, 2012 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
My amana front load washer wont spin and is showing an "nd" error message. what does this mean and how do i fix it?
Hi
Thanks for using FixYa. From what I understand the error code ND means “No Drain issue”. You’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag NFW7200TW Front Load Washer
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
Extremely loud spin cycle after belt replacement
It sounds like the belt is the wrong size meaning that it is to tight or to lose. Check to also make sure that the brake is disengaging and not rubbing on the drum
Apr 18, 2009 | Amana ALW480DA Top Load Washer
NFW7200TW washer won't engage spin cycle
We had the same problem with the same model machine and solved it.
Our machine was a month old and started getting stuck at minute 8, so we arranged service calls through Amana customer service. Long story short, the first three service reps couldn't figure out the problem. Two of them called Amana's in-house tech support line and the Amana techs didn't know what the problem was. The fourth repairman was smarter than his predecessors. He called the Amana in-house tech line, spoke to a rep who didn't know what was wrong, and then called in again. He explained that. based on his experience, some in-house techs knew more than others. That turned out to be the case because on his next call-in to Amana, that rep knew exactly what the problem was and recommended replacing the main computer board module. The repair guy ordered and installed the part. The machine has been working perfectly for a month.
Dec 25, 2008 | Maytag NFW7200TW Front Load Washer
Maytag NFW7200TW Front Load Washer Logo
153 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
