Question about Mustang 100 Manual PullDown Projection Screen
How to add lubricant to the cylinder for convertible top 1988 mustang
Seems the cylinder for my convertible top for 1988 mustang needs lubricant .. how do I add it ? Or suggestions to what else might cause the top problems going up /down?
Thanks.
Inside the front most part of the trunk is the top motor. Remove the blocking panel from inside the trunk to gain access. On the right side of the motor is a rubber plug that can be removed to check fluid level and to add fluid. Note that you can pickup the cylinder and turn it on it's side to fill it.
Be aware that if you have lost a substantial amount of fluid, the fluid level may simply be a symptom - and not the cause. Check for leaks by removing the back seat base and see if the floors are dry on the left or right side. If a hydraulic ram is leaking, it will leak fluid onto the floor at the sides of the seat area.
Posted on Jul 09, 2009
How to remove hydraulic lift cylinder from 2001 mustang conv V6
need to remove all plastic panels on the rear seat remove seat and remove the convertible top assembly complete
Sep 09, 2014 | 2001 Ford Mustang Convertible
Where do you fill 02 Mustang convert top hydraulic fluid
First be sure that one of your hoses to the cylinders aren't broken or disconnected, then follow the hoses usually they are right behind the rear seat or under it and possibly in the trunk your owners manual should say more about it if you don't have one your Ford dealer will have a service manual or you can go to your local library and copy pages from the repair manuls they have!
Jul 30, 2014 | 2002 Ford Mustang
Need firing order for 1988 ford mustang v-6
Sorry, 1988 Ford Mustang, only came with a 2.3L 4 cylinder or a 5.0L 8 cylinder, no 6 cylinder.
Sep 01, 2010 | Ford Mustang Cars & Trucks
How do i get access to the hydraulic cylinders for
through the trunk or remove back seat.Bottom snaps in at the front and back should have bolts at bottom where seat was.
Jun 14, 2010 | 1966 Ford Mustang
Convertible top won't go back up, can you help?
IT is probably a fuse. Does it work at all? my mustang had a busted cylinder and only 1 side would go up. If it doesnt work at all then check your fuses. With no manual you will have to use a flashlight and shine on them and see if one is blown. IF they all look good then I would go buy a testlight for about $10 and manually check the fuses for power. It oculd be the motor, however that will cost you several hundred dollars and that is if you install it yourself.
Oct 06, 2009 | 2001 Ford Mustang
Hi i have a 1988 ford mustang convertible with automatic trans
who ever changed that trans for you should told you about the difrence in trans after all they should have giving you some kind of warenty go back to the shop that change trans let them drive the car
Aug 20, 2009 | 1988 Ford Mustang
Electric rear windows 1988 mustang convertible not functioning
remove te rear trim panels and replace the window regulators, this is very common.
Jul 10, 2009 | Ford Mustang Cars & Trucks
Convertable top will go down but will not come back up.
I had the same problem with my 95 GT. You may have a leak in your system (motor, lines, cylinders). It seems there just isnt enough fluid to push the top up. I think Ford used the same system for 01 also. I had to replace the hydraulic cylinder that pushes the top up. My fluid leaked out because one of the cylinders was bad. This may be the problem. Located the motor and look for leaks.
Dec 08, 2008 | 2001 Ford Mustang
Mustang 100 Manual PullDown Projection Screen Logo
348 people viewed this question
Top Mustang Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mustang Office Equipment and Supply Expert? Answer questions, earn points and help others
