I have a Tecmar Ditto Max Professional tape driveand need software compatible for Microsoft xp. my old Ditto Tools (version 1.0 will not work with my new operating system.
    President:
  • 2,571 Answers
I looked for 30 minutes and found nothing.
The tecmar site has nothing.
DriverGuide has only audio drivers for tecmar.
This seems to be a very old device, have you tried compatability mode under windows.
As a last resort you could download a free virtual machine program, load a windows 95/2000 image and try to use it like that
Posted on Jul 18, 2010
Have an old Iomega Ditto tape drive Easy 800 and Ditto Tools software for Windows and Windows 95. Want to move data from old tapes onto Vista Op Sys and then onto a CD. Will this old software install on...
Is it possible to find an old computer running an old version of Windows, and then to connect the tape-drive to that computer, and then to copy the files onto a folder on that computer?
Then, if that computer has a network-card, you can "share" that folder, so that all computers on your network can then access that "shared" folder, i.e., to copy the files, and then to burn them to a CD-recordable.
May 05, 2011 | Iomega Ditto 800 External Tape Drive...
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
Jan 23, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
Need a driver for Visioneer OneTouch 8700 Flatbed Scanner
The drivers for supported OS versions are available here: http://support.visioneer.com/products/8700/downloads.asp . The supported OS versions are: Windows XP SP 1 / 2000 Professional / Me / 98SE and the additional software that was bundled on the CD is not included.
If you have a different Microsoft OS, you can check the Microsoft compatibility center for either Vidat or Win7. A check of the Win7 compatibility Center http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx showed some Visioneer OneTouch scanners work with Win7. However, the 8700F is not in the list.
I hope this helps.
(Dual boot with XP or a virtual computer with an older valid OS version will work. The Win7 Pro and Ultimate let you use Virtual PC and XP mode to run an XP virtual computer for free.)
Jan 03, 2011 | Visioneer OneTouch 8700 Flatbed Scanner
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
How to download ms office softwear
Hi 1.Please follow these steps to download ms office. 2. Go to http://www.brothersoft.com/downloads/microsoft-office-2007.html 3. There are some links in the above site. 4. Go through it and download the software.
Jun 21, 2010 | Tecmar OfficeBackup Workstation kit With...
Hi I have just updated my laptop to win 7 but i,m old fashion and still use Frontpage 98 yep I now old hey is there anyway I can get this to run on windows 7 or am i up for a new version
Like you I use Windows 7, and can tell you instantly that some older Microsoft programs do not work with Win 7, whilst some other ones do. If you have Windows 7 Professional or Ultimate you can try running Frontpage in Administrator and Windows XP compatibility mode.
Windows 7 Professional and Ultimate instructions:
A. Right Click on the Program name if installed (Could also try with install too if not installed)
B. Click on 'Properties'
C. Select 'Compatibility Mode'
D. Try using the different 'Compatibility Modes'. I would try 'Windows XP Service Pack 1' first, if this does not work, try 'Windows 98'
E. Click 'Apply' then 'OK'
F. Right click on the program name that you selected compatibility mode for above, and select "Run as Administrator"
G. Follow any further instructions
If this does not work, then it will probably be cheaper to find a used newer version on a site like eBay. Note that Frontpage 2002 has Windows 7 issues too, so please check out the following links.
Good Luck
http://social.answers.microsoft.com/Forums/en-US/w7programs/thread/649f6c9a-4b7e-4557-b136-bf90b3b3c9e2
http://www.microsoft.com/windows/windows-7/compare/default.aspx
Apr 25, 2010 | Microsoft FrontPage 2003
Microsoft office
Vista is the latest, so it can handle the newest things, to the things that were compatible with Windows XP. So, it can run almost anything.
It is natural that Microsoft is going to make Vista fully compatible with its old software. You can even install the crappy old OfficeXP or Office '98
Jan 05, 2009 | Microsoft Office Professional 2007 Full...
Is software Compatible w MS Vista Windows?
You will
have to install and run it using Windows XP Compatability Mode
Jan 02, 2009 | Microsoft Office XP Professional OEM w/...
Operating system error while installing roxio
Linux is much better than windows as for one you dont have to worry alot about viruses but pretening on installing that software maybe its just not compatible with windows
Dec 17, 2008 | Microsoft Windows XP Professional
Application Error
better uninstall the program and reinstall it..
Minimum System Requirements
Software
The 32-bit version of Autodesk 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft® Windows Vista® operating system
* Microsoft® Windows® XP Professional (SP2 or higher) operating system
The 64-bit version of 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft Windows Vista
* Microsoft Windows XP Professional x64
3ds Max 2009 30-day trial version requires the following browser:
* Microsoft® Internet Explorer® 6 or higher internet browser
3ds Max 2009 30-day trial version requires the following supplemental software:
* DirectX® 9.0c application programming interface (required)
* Some features of 3ds Max 2009 software are only enabled when used with graphics hardware that supports Shader Model 3.0 (Pixel Shader and Vertex Shader 3.0). Check with your manufacturer to determine if your hardware supports Shader Model 3.0.
Hardware
At a minimum, 3ds Max 2009 32-bit requires a system with:
* Intel® Pentium® 4 or AMD Athlon™ XP or higher processor
* 512 MB RAM (1 GB recommended)
* 500 MB swap space (2 GB recommended)
* Hardware-accelerated OpenGL® application programming interface and Direct3D® application programming interface supported
* Microsoft Windows – compliant pointing device (optimized for Microsoft IntelliMouse)
* DVD-ROM drive
Note: Apple® computers based on Intel processors and running Microsoft operating systems are not currently supported.
At a minimum, 3ds Max 2009 64-bit requires a system with:
* Intel EM64T, AMD Athlon 64 or higher, AMD Opteron™ processor
* 1 GB RAM (4 GB recommended)
* Hardware-accelerated OpenGL and Direct3D supported
* Microsoft Windows – compliant pointing device (optimized IntelliMouse)
* DVD-ROM drive
Nov 03, 2008 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
