Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Compressor not cooling r134a - Frigidaire FRS3R5EMB Side by Side Refrigerator
  • Frigidaire Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezercompressor not cooling r134a - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigeratocompressor not cooling r134a - 2_bing.gif"http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 19, 2010
How do you convert from r12 to134a
Recover R12 then flush system. Change drier or receiver tank depending what vehicle you have. Change expansion valve or orifice tube again depending what vehicle you have. Install the R134a Hi and Low service ports and put the correct amount of compressor oil for R134a freon into compressor. Pull unit into a vacume for about 15min. and leave it set for another 15 or 20min. to make sure it stays in a vacume and there are no leaks. If it holds a vacume charge the unit with the correct amount of R134a and run unit and check that it operates and cools properly. If all is good install the service port caps and your done.
Jun 24, 2014 | Cars & Trucks
Can 134a refrigerant be put into a R12 a/c system?
no --it cannot. R12 gas operates at a far lower pressure that r134a so if you want to use r134a gas you will have to replace compressor ,evaporator and condenser and have a cooling fan for the condenser fitted
May 20, 2014 | 2000 Chevrolet Cavalier
Replaced all A/C major components (compressor, filter-drier accumulator, and orifice tube) except condenser due to a seized compressor and failed clutch bearing. Flushed system and appeared to have no...
It sounds like you've done just about everything except to check if there is a bad or intermittent wire causing this or perhaps your low-pressure safety cutout switch is possible going bad causing the compressor to kick on and off?
Nov 01, 2013 | Lincoln Town Car Cars & Trucks
Were di i recharge the ac on my car
if it is the 3.4 v6 the low side is on the passager side behind the motor. it should have a blue cap on it, and the low side is the fatter of the two ac lines
Aug 08, 2010 | 1994 Pontiac Grand Am
Air Conditioning don't get cool I check the freon and replace it....but still not cold...help..
First, does the compressor rotate around the pulley area when the a/c is turned on?
Also, does the fan turn on at the radiator when the a/c is turned on?
Also, is the a/c blowing through the vents?
How much pressure is on the low side when the compressor is turning? It should be 25psi to 45 psi on the low side according to the gauge connected to the hose which is connected to the can of freon.
I usually recommend putting some of that arctic freeze r134a in cars. It has a leak seal and lubricant, and a special additive invented and approved by NASA that helps to cool 50% faster and more efficiently than regular r134a.
Many people experience leaks that can require 2 or 3 cans of r134a if it leaked out.
Good luck on this repair.
Jul 25, 2010 | 2003 Chrysler Town & Country
Air is not very cold on a rv roof top ac what tools are needed in recharge
You should have the manual for this unit handy and as far as recharging tools go. You only need a can of R134a *(if the unit is R12 you need to buy upgrade adapters since R12 is no longer sold) Run the unit and put the R134a filler line on the low pressure side of the compressor *(from manual...dont guess as trying to charge the high pressure side is VERY dangerous). Get the charge just into the Green zone on your charger and that is it! Try not to fill too high in the green zone....I know it sounds funny...but AC's usually work better when they have the low end of their optimum fill. R134a doesnt work as well as R12 so be sure you buy the R134a with cooling enhancers. Your local Autozone can guide you to the right filler/product combination.
Good luck and be careful!
Jun 30, 2010 | Dometic Rooftop RV Air Conditioner
Compressor runs but coils don't get cool to shed water
if the compressor is really running (not just the fan) and it doesnt cool the evaporator coils then it has lost its refrigerant (likely r134a) .. thats a special job to repair.. there also has to be a leak that must be repaired .. then the system is refilled and possibly a dryer added .. if the fan is running only, then there are many other possibilities .. .. you shouldnt run the unit long since part of the cooling for the compressor comes from the refrigerant .. it will shorten its life if run a long time without it ..
Aug 01, 2009 | Haier HD451E Dehumidifier
What type of freon is in a 1994 GMC Suburban
There should be a lable underhood.but probably had R-12,Best to go ahead and convert to R134A.Recommend replace reciever drier ,buy conversion fittings from parts house for 134A,remove compressor turn upside down and rotate clutch by hand to get as much oil out as you can,then pour in aprox 4 oz pag oil.Reinstall,change orfice tube the will need aprox 12 oz R134A to replace 16oz R-12.Buy R134A at walmart cheaper than all parts houses by at least $2.00 a can.Cgarge till low side preasure at aprox 40 to 45 psi and gigh side 200 to 250 psi.Should cool fine.
Jun 19, 2009 | 1993 Chevrolet Suburban
2001 Mustang Gt A/C not cooling
You might not have enough R134A in it the system should hold 3 - 5 lbs of pressure if I remeber right. But if the clutch is kicking in then its working but you might not have enough R134A. Buy the kit that has the pressure guage with a trigger on it so you can add what you need. When you fill it turn car on and ac on high then fill it. When ac is off the clutch should spin freely if not then your compressor is junk. As for the slight grinding noise just to make sure with CAR OFF turn the clutch on the compressor and make sure its not rubbing the pulley on the compressor.
Apr 09, 2009 | 2001 Ford Mustang
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
243 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
