Question about Kenmore 53632 / 53634 Side by Side Refrigerator
Kenmore refrigerator model # 106.53632300 freezer doesn't freeze. it was hot to touch. I vacuumed the coils and it isno longe hot to touch but freezer still doesn't freeze.
  • 6,784 Answers
If you are not hearing the compressor cycle on and off in intervals and there is no air flow present inside the unit, this will confirm that there has been a severe malfunction within the units assembly. You will need to check the following areas for faults:
1. Compressor- Make sure this unit is functioning. if it is not cycling as designed, this will be the culprit. If it is cycling but very hot to the touch when operating, check the condenser coils for debris and clean them if necessary.
2. Compressor start relay - This is the main on/off switch that is attached to the side of the compressor. This relay, when energized by the main control board, starts the compressor. if the relay has failed, it will not start the compressor, thus, rendering the unit inoperable. Pull the relay off and shack it. If it rattles, replace it.
3. Evaporator fan - This is a very important part of the evaporator core. This is the principal air mover of the unit. If this fan fails, the inside freezer and refrigerator will not cool, at all. You will need to remove all the freezer shelves and content to access this unit. It is concealed behind a panel inside the back section of the freezer compartment. Once the concealment panel is removed, you will expose the core and fan. the fan can be tested with a multimeter for proper continuity. You can also jump the terminals with a jumper wire to see if it is still in working order. An external power source will be needed for this test. if the fan fails the test, replace the fan motor.
4. Condenser fan - This is also a very important fan. This fan is mounted near the condenser coils and can fail. You can test it in the same manner as the evaporator fan. replace the condenser fan if it proves to be damaged. This fan must spin at a fast rate when the compressor is activated. If it fails, it will allow massive heat to build up in the coils and compressor unit, thus damaging the internals of the compressor.
5. Main PCB(Printed Circuit Board)- This is basically your main power controller. This board routes power to all the fans and compressor unit located in the assembly. it also routes power to the lights and ice maker/dispenser, as well. This will be the most expensive repair, in this case. If all the above areas prove to be functional, the main PCB will be the culprit. You can easily locate this board. It is usually mounted on a bracket, near the compressor platform, or behind a concealment panel on the rear of the unit. Once you have gained access, visibly, inspect the board for burn markings at the relay mounts and jumpers. check the entire circuit board for discolorations like brown marks or black burn marks at the plug-in connectors. If this refrigerator is totally dead, this will be the cause.
6. Monitoring thermostats - These are located in each compartment. Replace each thermostat if all above checks out ok.
You will find the culprit in one or all of the areas stated above.
Posted on Jul 18, 2010
Kenmore Elite fridge cools but we noticed the compressor and fan never turn off. Compressor is very hot to touch. Do we need to replace compressor or a relay switch or ...? Thoughts/suggestions?
Newer refrig. Run almost continuous but you could try cleaning the condenser coils, located on back with vacuum and brush also place thermometers in freezer and mid level refrigerator, freezer should run 0 to -8 F and refrigerator 34-37 F. If much lower adj. thermostat up.
Sep 16, 2017 | Kenmore Refrigerators
Kenmore model 71184100
have you ever cleaned the coils? dusty coils make the 'Frig work harder
Aug 05, 2013 | Kenmore Dryers
Stopped cooling
My refrgerator a Kenmore, model 106-71182101, with ice maker stopped cooling and freezing.I vacuumed the condenser coils, and
fan in the rear bottom, along with any other debris. I unplugged the frig because the compressor was very HOT!.Question? Could the compressor have a Locked-Rotor? If so what can I do to loosen it.
Apr 08, 2013 | Kenmore 18.3 cu. ft. Top Freezer...
Have a kenmore elite not getting cole and not freezing
Have a kenmore elite not getting ?????. if not getting cold . ck to see if both fans are gong and if compressor is hot to touch . if its not hot its not running . this could be a cold control/ or stuck in defrost . if the lights or on inside / the power is ok . but you need to ck some of the controls . and see if comp is hot . it may be a compressor also .. **** i know this does not help much but i need more info to help more thanks ****
Apr 04, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Kenmore Coldspot side by side fridge/freezer no longer cold.
The black thing is the compressor. It should run warm but not hot. This usually indicates it's time to clean the condenser coils under the refrigerator. Try using a long soft brush and your vacuum cleaner.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Sep 01, 2008 | Refrigerators
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 53632 / 53634 Side by Side Refrigerator Logo
231 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
