Question about Kenmore 64802 Top Freezer Refrigerator
WHAT IS THE CUBIC FEET 596.52673200 - Kenmore 64802 Top Freezer Refrigerator
  • 13 Answers
SOURCE: Need to know what cubic feet a 2005 Model #
25-27
Posted on Jul 31, 2009
localwonder
  • 6784 Answers
SOURCE: The refrigerator side is not cold.
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device and thermostat.
Posted on Aug 27, 2009
Testimonial: "The information was helpful and solved my problem. I also learned something about the operation of my refrigerator. Thank you"
woodchuck789
  • 4070 Answers
SOURCE: How to check defrost timer on Kenmore side by side
You don't have a defrost timer, you have an adaptive defrost control which determines when to defrost based on how often door is opened etc. If you have a defrost problem check , defrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the heater and thermostat are ok it’ll be the control.
Posted on Sep 08, 2009
Testimonial: "Thank you"
heatman101
  • 43501 Answers
SOURCE: kenmore model # 78207890
Here is a tip that I wrote that tells you how to figure out how big yourrefrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Posted on Jul 26, 2011
richroth
  • 9472 Answers
SOURCE: What is the cubic feet of kenmore coldspot refrigeratior model #106.9530482
This is a 20 cubic ft. side by side refrigerator.
Posted on Oct 17, 2012
Formula cft to bbls
Cubic Feet to US Barrels (Oil) conversion
www.metric-conversions.org > ... > Volume Converter > Cubic Feet Conversion
  1. Cached
  2. Similar
Bookmark Page US Barrels (Oil) to Cubic Feet (Swap Units) ... 0.00US bbl oil. ... In metric terms a cubic foot is a cube with sides 0.3048 metres in length.
Cubic Feet to Barrels conversion
www.metric-conversions.org/volume/cubic-feet-to-barrels.htm
  1. Cached
  2. Similar
Cubic Feet to Barrels (ft³ to bbl) conversion calculator for Volume conversions with additional tables and formulas.
BBL to ft3 - How many cubic feet in a barrel? - Ask Numbers
www.asknumbers.com/barrel-to-cubic-feet.aspx
  1. Cached
  2. Similar
Barrels to cubic feet (bbl to ft3) conversion table and converter. How many cubic ... Conversion Calculator ... US Barrels [Fluid and Oil] To Cubic Feet Conversion.
Cubic Feet To Barrels (ft3 to bbl) Conversion - Ask Numbers
www.asknumbers.com/CubicFeetToBarrel.aspx
  1. Cached
  2. Similar
How many barrels in a cubic foot ? ... Conversion Calculator ... Cubic feet to fluid barrels (bbl) conversion table shows the most common values for the quick ...
Formula cft to bbls Google Search
Jan 30, 2017 | Formula Computers & Internet
A room is 22.3 Meters wide, 20.56 m long and 6.5 m high How do I calculate the number of cubic feet in the space.
The volume is about 105,244 cubic feet (that's about 105 thousand).
One foot is 0.3048 meters, so one cubic feet is about 0.0283 cubic meters, or, by taking reciprocals, one cubic meter is about 35.315 cubic feet.
Nov 22, 2016 | Miscellaneous
6000 cubic feet equals how many sq. feet
You can't convert cubic feet to square feet because cubic feet has an extra dimension, you could fit an unlimited number of square feet into cubic feet.
The formula for Cubic feet is:
length × width × height
The formula for Square feet is:
length × width
Aug 19, 2016 | Office Equipment & Supplies
How much area will be covered with 36.78 cubic feet of mulch please answer in feet and inches
How it Works
Stone and Mulch Calculators
As an example, let's use 500 square feet to be mulched at a
3" depth.
  1. First, the depth must be converted to feet. To convert inches to feet, simply divide inches by 12, the number of inches in a foot.
    So for our example: 3 inches divided by 12 equals a 0.25 foot depth.
  2. Now that we have the depth in feet, we can multiply the depth by the area.
    So for our example: 0.25 foot depth times 500 square feet equals 125 cubic feet.
  3. If you are calculating 0.5, 2, or 3, cubic foot bags, simply divide 125 cubic feet by the size of the bag.
    So for our example: if we are using 2 cubic foot bags, we can divide 125 cubic feet by 2 which equals 62.5 bags.
  4. If you are calculating cubic yards, we need to convert 125 cubic feet to cubic yards by dividing by 27. One cubic yard is equal to 27 cubic feet, see the diagram below.
    So for our example: 125 cubic feet divided by 27 equals 4.63 cubic yards.
For Your Information
  • 1 inch equals 0.08333 feet
  • 1.5 inches equals 0.125 feet
  • 2 inc
Jun 29, 2016 | Office Equipment & Supplies
Area 40 ft long 4ft wide 5 inches deep how many sq yards needed
First step - convert everything to feet - 5" is 5/12 of a foot
40 x 4 x 5/12 = 66.6 cubic feet.
Since a cubic yard is 3 feet by 3 feet by 3 feet, there are 27 cubic feet in a cubic yard.
66.6 cubic feet / 27 cubic feet/cubic yard = 2.5 cubic yards.
Good luck.
Paul
Apr 15, 2016 | Office Equipment & Supplies
How to calculate cubic feet ?
Calculating the cubic feet of a space requires multiplying the area of the bottom times the average height. You get the bottom area by multiplying the length times the width. Remember, to get cubic feet, you need all your measurements in feet to start with.
Here is your formula:
VOLUME (in cubic feet) = Length (in feet) X Width (in feet) X Height (in feet)
If it's a rectangular room you're working with, it is all straightforward. If there are irregular walls, it may be necessary to divide up the room into rectangular sections and then add together their individual volumes. If the ceiling is sloped, you need to use the height that has the same ceiling area above it as below it. Good luck! Truly.
Jul 25, 2014 | Building Materials
How to calculate cubic feet?
Multiply 21 inches by 14 inches by 10 inches to get 2940 cubic inches. There are 12 inches in a foot, so there are 12^3=1728 cubic inches in a cubic foot. Divide 2940 cubic inches by 1728 cubic inches per cubic foot to get about 1.7 cubic feet.
Alternatively, first convert all measurements to feet. 21 inches is 1 3/4 feet, 14 inches is 1 1/6 feet, 10 inches is 5/6 feet. Multiply them together to get 245/144 cubic feet, which again is about 1.7 cubic feet.
It's always nice when doing a problem two different ways gives the same answer.
Jul 04, 2014 | Office Equipment & Supplies
Cubic feet calculator
What unit are the numbers in?
40 feet by 45 feet by 5 feet is 9000 cubic feet.
If the numbers are in inches then the volume is about 5.2 cubic feet.
If the numbers are in meters then the volume is about 317,832 cubic feet.
Apr 03, 2014 | Office Equipment & Supplies
Kenmore 64802 Top Freezer Refrigerator Logo
276 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
