Question about Acer NSK8458AN Keyboard
How do i find & use the under scor key? - Acer NSK8458AN Keyboard
  • scscpc Jul 18, 2010
    i do not have a shift key marked on this lap top now how do i find the underscor key computer is a acer laptop note book number aspire 7540-1408
  • 532 Answers
The under score key is on the 2nd roll in between zero key and =+.
Hold down the shift key and the key i told above and it will bring the under score out.(_)
Thanks
Posted on Jul 18, 2010
I recently completely rebuilt my 2001 rm125, I then ran it with the wrong jet needle, leaned it out, and scorred my cylinder, I then honed the cylinder with a cheap 50 dollor hone and put the jug back on...
replace the rings as they have lost their tension
make sure that they are free to move in the grooves as to score a cylinder normally results on the ring lands closing up on the rings and jamming them
Jul 29, 2017 | Suzuki RM 125 Motorcycles
How to open trunk without key WHEN BATTERY IS DEAD 04 LINCOLN LS
some had a cable release by the drivers or back seat door near the floor..in extreme cases, remove the back seat and crawl thru and release manually
Feb 07, 2013 | 2004 Lincoln LS
Putting key back on
I think you need to be a micro surgeon to successfully get the key back on. I know of few that have successfully gotten them back on.
The good news is that the keyboard is replaceable and not very expensive.
You can sometimes use an external, wireless keyboard as a workaround...
Jan 01, 2013 | Computers & Internet
My Kawasaki kx80 locked up on me n i got it going again n put new piston n ring in it but there's still a tapping sound it there
The engine will require running in as the bore must have been scorred as well and should have been scoured with wire wool to allow the rings to bed in.
Is the tapping coming from what you have replaced?
Find a long screwdriver and put the tip on the top of the engine and the handle up against your ear and listen. Locate the source of the knocking/tapping and then you will know the cause and area.
Hope that helps.
Mar 17, 2011 | 2003 kawasaki KX 125
How can I change the password for my Belkin Wireless G Plus MIMO (F5D9230-4) Router?
Hi
1. Connected a computer to the router using a Ethernet cable.
2. Open up a internet explorer.
3. Click on CTRL & O [The letter O as in oscar]
4. In the Open box that appears the top left corner of the internet explorer type the numbers : 192.168.2.1 & press OK.
5. This will take you to belkin router setup screen.
6. Click on Channnel & SSID under wireless on the left side of this screen.
7. Once it prompts to type the password just leave the password box blank & press submit.
8. Change only the SSID to different name to what ever you wish like in last name & press apply changes. [do not change any thing else in this screen]
9. Click on Security under wireless in the left hand side.
10. Choose the security mode to WPA-WPA2 personal PSK & in the pre-shared key make up the password to what ever you wish & then press apply changes.
11. Now try to connect to the wireless network using the new SSID [network name] & the new password that this the security key that you set up in key one.
Thanks
Dec 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Reboot and select proper boot device or insert boot media in selected boot device and press a key message coming upon my hp mini 110
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
?????????????????? hope this helps
Dec 27, 2010 | HP Mini 1000 Netbook
Ferrari 1100 cd drive wont read oor write
Please try this :
Open the registry under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
[to open the registry, vista or 7, navigate to start, then type in regedit, choose from list, right click and say open as administrator. On XP, navigate to start, choose run, type in regedit and hit enter]
Then find the DVD & CD ROM key under above value.
Under the DVD & CD ROM key, find the values UpperFilter & LowerFilter and delete both seperately. Reboot machine and recheck. See below for picture
May 28, 2010 | Acer Ferrari 3200 Notebook
How do you transfer game scors and attchivements from profile to profile
If you have XBox Live at all, you can simply hit recover profile in your "My XBox" section.
Feb 01, 2010 | Microsoft Xbox 360 Console
Car will not crank
go under driver side of dash find after market box may have alarm name on it probably just stuffed upped under dash unhook wires tape as nec there is two heavy wires yellow or white may bee cut nec to re solder & tape car should crank & start
Aug 30, 2009 | 1995 Buick Riviera
Water in the crankcase
Hello there:
I am sorry to tell you this but a upperend overhaul is going to be your best solution i have worked with johnson/evirude to bayliner products for over 15 years experience and certifications and this is a common problem unfortunatly the repair isnt ok ?
contact your local authorized dealer for further repair details.
best regards mike
(USN RETIRED)
Aug 15, 2009 | Sport & Outdoor - Others
Acer NSK8458AN Keyboard Logo
93 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
