Question about ASUS Intel 815E Chipset TUSL2 (TUSL2 SWA) Motherboard
Not read actually
My hdd has detect on bios setup..but the capacity of my hdd not true....
but i try that hdd to another comp n i install xp,its working...my mainboard have limit capacity of hdd or what???
    President:
  • 2,351 Answers
It is not about the motherboard. It is about windows. When setting up windows (New install), windows may not see all of your drive. That's OK. Once windows has finished installing & all your drivers have been installed, please update windows.
Once Windows SP1 & SP2 have been installed Windows will see all of your hard drive.
Windows 98 can see a max of 64GB & windows 98SE, 137GB. Win XP can see a max of 2 exobytes.
(What is 1exobyte? = EB. In decimal terms, an exabyte is a billion gigabytes).
Enjoy!
Mike
How to repost more questions for same problem or answer expert's questions.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Add another question to the current post.
Posted on Apr 24, 2008
When i m installing xp sp-3 cd it get boot and setup get satrted but after somtime it say there is no Harddisk in your System??????
first try to detect your hard disk from BIOS setup as primary, if detected then run setup again, if still not shows the HDD it mean media or storage of HDD got corrupted you have to replace them.
Aug 18, 2011 | Acer Aspire T650 (AST650UC3601) PC Desktop
I can't install Window Xp sp 2 in My Compaq CQ45 .If i stall Xp sp 2 ,it can't found HDD..
Restart your PC and go into BIOS Setup. For some computers BIOS setup keys are F2 and for others its Del key. If you are not sure which key takes your computer to BIOS setup. Start pressing F2 and Del keys alternatively immediately after you restart your machine. Make sure that your HDD (Hard disk Drive) is detected. If its not detected and appearing in the BIOS setup than most probably you have to open your hardware which is not recommended if you are a beginner. There can be a number of reasons like loose wiring and bad jumper settings on the hard disk id the disk is IDE.
May 05, 2011 | Computers & Internet
Hello, Where could I find a driver for WD5000KS SATA? I am trying to upgrade my desktop PC to Win 7 but when installing it, the setup could not detect the SATA HDD and asked me to load the HDD driver. ...
Check in your BIOS,first make sure the SATA controller is set to native mode and not RAID, and secondly that the BIOS can detect the drive, if the drive can't be detected by the BIOS then it's because the drive surpasses the boards drive size limitation.; If this is the case there is a chance a BIOS update may fix it but it's not guaranteed it will.
Jan 05, 2011 | Western Digital Caviar SE16 (WD5000KS)...
Ibm thinkpad r60 hard drive not recognized by
make sure your operating system having a sata drivers,if u r using sata HDD,try to install vista or 7 it show HDD but if you run XP it not detect HDD because XP dont have sata drivers,or burn XP using Nlight software add sata drivers in that
Nov 14, 2009 | IBM ThinkPad R60 Notebook
New HDD not recognising on laptop
what size capacity is the new hard drive - and what is the bios on your laptop able to recognise ?
is it an upto date laptop ?
some old bios's unable to see newer larger drives....
try updating the bios of your laptop
or use a hdd prep programme
Oct 11, 2009 | Computers & Internet
HDD not recognized whe installing fresh Windows XP!
Hi...
If your HDD will not recognized during installation you need to check if your HDD is detected. Try to look at your BIOS if it is detected. IF the HDD will not detected you need to replace the cable, try to use the other slot of your SATA or IDE ports.
Regards
ICmanServer
Jul 31, 2009 | Dell Vostro 1400 Intel Core 2 Duo T5270...
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
Gateway MX6960 stuck on "Press F11 to start Recovery"
SATA drivers are on the xp disk,you just hit F6 during the install,when it ask you to.
Setup boot can be downloaded from here Just scroll down to the xp section and download to your desk top.Make sure you have 4- 6 floppies ready.once downloaded to the desktop,double click and follow the instruction.
Please take time to rate this fixya solution.
Jan 22, 2009 | IBM ThinkPad T22 2647 Notebook
Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
May 18, 2008 | Computers & Internet
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
ASUS Intel 815E Chipset TUSL2 (TUSL2 SWA) Motherboard Logo
77 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
