Question about Proform Exercise & Fitness
I would like to program my proform520x for my work out how do I get a manual to do this
    President:
  • Proform Master
  • 832 Answers
Go to iconservice.com click on manual here is the info you will need:
PROFORM 520X TREADMILL (DRTL5922)
Posted on Jul 19, 2010
Resets after begin
My Stairmaster unit seems to work in manual mode, but resets when I select a program. What is wrong? It is possible that the console on your Stairmaster unit may not be configured for the appropriate machine. This can result in the console accepting and allowing a manual workout but not accepting or allowing a program. Stairmaster Units Works in Manual Mode but Not in Program
Feb 24, 2014 | Stairmaster Stepmill 7000 Pt
Casio tk 1550
On most models, there is a top, bottom and commercial message. Make sure you are programming the correct one.
If anyone needs a programming manual for the Casio TK-1550, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1550_user_programming_manual.html
Dec 14, 2013 | Computers & Internet
Stairmaster won't have a continuous workout
Nov 01, 2012 | Stairmaster Exercise & Fitness
I reset my ce3700cas register, and would like to program the taxable button, can u pls tell how.
You should not reset the memory unless you have the MAC codes and programming information ready. If you have put the wrong MAC code in, you will have problems straight away. I don't have codes for this model since it is now very old. You should get a programming manual and work through the country, monetary system, decimal places, date structure etc for your country before you start programming anything else. There are two setup manuals for RAM clearing this machine. If you don't have both, you can't do all of the programming. C-tech has them on his site:
MAC codes for memory reset in this manual:http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_and_CE-3750_service_manual.html
User programming in this manual:http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_operators_and_programming_manual.html
Jan 31, 2012 | Casio Parts Cash Register PC Desktop
Need to know how to manual over ride intermatic lighting programable timer.
The Intermatic battery-operated timer series override button is either the on-off button or push in the door that acts like a switch and pushes on-off button.
The manual override reverses the programming, and then programming resumes at next set point.
So the override does not disengage timer programming.
Open following link for ST01C timer manual and ez programming.
http://waterheatertimer.org/ST01C-programming.html
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 06, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
I programmed the timer to go on and off at a specific time and it doesn't work. The time of day and the date are working fine. It is only programmed for one light.
To program the ST01C:
http://waterheatertimer.org/ST01C-program.html
ST01C manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
1) Manual has troubleshooting. Since ST01C is battery operated, it will not work on loads farther than 100 feet away from timer. If a wire is buried underground, this can interfere with operation. Other electrical devices can interfere with timer operation.
2) Solution:
a) Check for interference issues listed above.
b) Press MODE and make sure it is set to AUTO. If timer will not enter AUTO then no program has been set.
c) Re-check your programming as shown in step 6 of manual. Remember timer offers 40 programs. To set Program 1 >> 'on' time has to be entered and saved for Program 1 >>> and then 'off' time has to be entered and saved for Program 1. And then press MODE and set to AUTO.
Sep 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
TRU348---NEED MANUAL TO PROGRAM TELEPHONE
Here is the link to the page with the manual to download. Hope you get it programmed soon! http://www.uniden.com/products/productdetail.cfm?product=TRU348
Feb 07, 2009 | Uniden TRU348 Cordless Phone
Exercise & Fitness Logo
55 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
