Question about Samsung T220HD LCD Monitor
Monitor goes blank after 5 seconds, what do i need to do?
    Genius:
  • 1,478 Answers
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Posted on Jul 18, 2010
    Problem Solver:
  • 19 Answers
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. I have replace three so far but the price of the sower supply replacement and trying to get it apart its better getting a new one. The have gotten cheap and cheaper. You can see if the monitor part is still working taking a flash light and holding it about a 45deg angle to the screen and look at the screen at the other angles. You get the light to bounce off the back light and see a faint image where the light is hitting. Its not easy unless like taking thing apart. Use the number on the power supply if your going to find one.
Posted on Jul 19, 2010
Monitor flickers and goes blank after 5 seconds and keep repeating this very often.
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
Take care.
Jul 26, 2010 | Acer AL2016W 20" LCD Monitor
Screen goes blank when first turned on, have to keep restarting m
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Monitor goes blank after 5 secons
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 10, 2010 | Computers & Internet
Screen goes blank after 5 seconds switching on
The picture board on your monitor is bad, since it goes blank after five seconds, it shows that the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Proview PX 780 Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
I turn my monitor on and it lights up then goes blank.
sounds like you have a backlight problem, the wires are known to burn off the ends of the bulbs of the back light..if you try to repair it yourself be careful the lcd screen and bulbs are frigile.. there is 4 bulbs two on the top and two on the bottom of the screen ,, keep every thing in order when taking apart
Aug 01, 2009 | HP w1907 LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
The screen goes blank after 5 seconds
Make sure you have the correct drivers install for you video card. Also, check to make sure your resolution is not set to high for you video card. To get to resolution; right click on Desktop > click Properties > press Settings Tab, from there you can move the slider to change your screen resolution (try different resolutions until it doesn't shut off anymore).
Let me know.
Jul 09, 2009 | ViewSonic VG900b 19" LCD Monitor
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Samsung T220HD LCD Monitor Logo
769 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
